Old 04-05-2013, 03:57 AM
Snowman73 Snowman73 is offline
Mein Auto: X3 3.0d M-Sport (2013)
On my X3 - you can turn off the daytime running lights - its an option in the idrive under menu>settings>Lights. However, your auto lights are (as everyone is aware) turned on/off by the light switch on the dash which obviously uses the sensor. My old 330d used to put side lights on when getting dark and then full lights on when it was dark. I haven't tested if the LED angels come on when it is getting dark but when you have the daytime running light option set to "off" - will do that this weekend unless someone else knows. If its only the side lights coming on when its sunny, then I am happy with that, but if its the full lights then that is different.
