Old 04-21-2013, 10:12 AM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
Before...
Originally Posted by Gootz4u View Post
Ok guys, here is an update. Under the cabin air filter I found two 30 fuses that were blown I replaced them and I am back to my first issue which is engine fail safe program and the codes are P0120, P0123, P0223, P0103, because I had these codes at the beginning, I replaced the Throttle Body and it still wont work. I did try something else just to check. I disconnect the fuel line where the fuel rail is and placed a small container to see if gas was coming and when I turn the key. When I turned the key, no gas came out. There is no gas going to the fuel rail. Hum..... Fuel Pump?
I'd check the fuel pump I'd most likely pull the line off going into the fuel filter...turn the key to the 'run' position and fuel should spill out of that (could be clogged filter), If you have no fuel going into the fuel filter then I'd verify the fuel pump relay and fuses first then if you have nothing there then I'd check voltage at the fuel pump with the key on if that is ok then yep fuel pump...Good Luck
Easy stuff first ALWAYS
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
