Bimmerfest - BMW Forums - View Single Post - Changed from 18" to 20" - tpms malfunction
Old 04-21-2013, 07:09 PM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
Originally Posted by Wolfman64 View Post
Is that true? Never seen that before. As long as the sensors have the right frequency, shouldn't that just register within some miles of driving/reset?
I have had sensors with a bad battery which needed replacement, or the wheels could have been sold without sensors.
Are the valve stems metal or rubber? If rubber, there are no TPMS installed...
They will be need to be programmed. it is the same situation if you were to replace one of the sensors on your current wheel setup. The "address" of that new tpms sensor would need to be programmed to the car so that it can speak to the car.
