Bimmerfest - BMW Forums - View Single Post - 2004 BMW X5 Panoramic Sunroof - Faulty
Old 04-24-2013, 12:07 AM
sunny43.5 sunny43.5 is offline
Mein Auto: Sorry VW,s
Hello again form down under thought it would be a good time to repost the instruction and photos as they are back on page two and no one seems to find them so here goes .
Hi again all I have decided to post the repair for all to see , I don't always check the actual website page so some will miss out on a reply . So here it is .
Regards From Howard
I have included two photos for you its really easy to fix the roof , just open the front roof {slide back ] look down from the top and you will see two plastic fittings one on each side remove the metal spring that you can see then the link arm will probably drop down just remove it and discard along with the spring , the next thing is the very front part of this plastic part is sort of triangular in shape . You only need to remove the front piece the first one I used a Fein saw the second one I just used a pair of side cutters much easier , once you have done this on both sides close the roof and make sure you have closed the rear one if its still vented just push the two wedge shaped fittings on the underside rearward and the back glass will close down . Then reprogram the roof press and continue to press the centre of the button for about 60 seconds the roof will then go through all its functions do not remove your finger until the roof closes and the blinds have finished closing , then all should be fine Regards Howard
PS if you only want to close the roof just push back the two ramp fittings inside under the rear glass , push them backwards a bit at a time each side you should then be able to close the front glass , remember not to use the roof again until you do the modification or you will have to reclose the rear glass again .
[IMG]http://
