Bimmerfest - BMW Forums - View Single Post - F10 Retrofitting Lane Departure Warning
Old 05-03-2013, 12:01 PM
Bavarian88 Bavarian88 is offline
Mein Auto: BMW F11 M550d
hello
my name is christian from Bavaria Dingolfing
i Need some help
i want to retrofit the Lane Departure Warning
1. i have installed steering wheel with Vibration module
2. i have Lane Departure Warning that i have added to the (SA) Special Equipment List with Esys
3. i have coded it in the following order:
KOMBI:
3003, TLC_VERBAUT, aktiv
3004, ST_TLC_TIMEOUT, aktiv
3004, ST_TLC_ALIVE, aktiv
3004, ST_TLC_APPL, aktiv
KAFAS:
3000, TLC_START_VERSION, default_on
3000, TLC_ON_OFF, aktiv
3000, SEND_MESSAGE_327, aktiv
3000, SEND_MESSAGE_345, aktiv
3006, ACTUATOR_ON_OFF, aktiv
HU_CIC:
3001, LANE_DEPARTURE_WARNING, aktiv
SZL_LWS:
3000, Lenkrad_Vibration, aktiv
FRM
LIN_PUBU_TLC, aktiv ( this one i havent coded, i havent got the button)
i get an error when i restart the car :
-LANE DEPARTURE WARNING FAILURE
I only get this error if i code this : 3006, ACTUATOR_ON_OFF, aktiv
my car has Head UP Display , High beam assistant, Speed Limit Info
please help me !!! thank you
