Bimmerfest - BMW Forums - View Single Post - Servotronic as an option?
Old 05-08-2013, 06:22 PM
3drockz 3drockz is offline
Mein Auto: BMW X1 x128
Originally Posted by Michael Schott View Post
There is no way to "loosen" the steering unless Servotronic is just a software change and it's doubtful that a dealer would recode. Make sure your tires are fully inflated as low pressure would cause higher steering effort. If you can handle the slightly rougher ride, go a few PSI above the recommended pressure settings. But just a few as overinflation can be bad for tire life and will cause extra wear on the center of the tread.
Alright, I'm upset that it can't be loosened... but will try that out. Thx
