Bimmerfest - BMW Forums - View Single Post - AC not working 2001 X5
Old 06-08-2013, 05:20 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Originally Posted by David Covell View Post
Replacedaux fan today. Not a big job. Still no ac. Before I make my next step, I would like to ask where to find the 50 amp fuse behind the glove box. Looked into the courtesy light area, where there is a pull down panel, but no fuse. Fuse box has 50 amp fuses, but all look good. Engine compartment at glove box location has no fuses.
Can someone identify where this 50 amp fuse is??
Thanks,\
David
Did you test to confirm that the fuse has power to them? The 50 amp fuse is right behind the glove box behind the pull down panel.
Did you test to see if you have power at the fan connector?
There is a spare 50 amp fuse also in that panel so it will not have current since it is not connected.
