Bimmerfest - BMW Forums - View Single Post - Got the 1.2 bar expansion tank cap from German Auto Solutions
Old 08-03-2013, 05:51 PM
I was doing some research for someone needing a coolant bleeding DIY, when I ran into this cryptic sentence:
Originally Posted by Aussie528iT View Post
The expansion tank does not have an overflow tube. Coolant is vented through the cap (cap is hollow inside) and any over flowing coolant will leave white stains around the top of the expansion tank. This is normal but leads some people to think their expansion tank is faulty and leaking
So, if the expansion cap is the one-way coolant overflow valve (with a two-way air check valve built in), then what is the purpose of the so-called expansion tank overflow tube that goes from the expansion tank neck to the top of the radiator?
