Old 08-21-2013, 08:12 AM
cn90 cn90 is offline
Originally Posted by 1BADBM View Post
...I jumped the relay yesterday pump kicked on, replaced the relay and it wont turn on. Could jumping the fuse mess anything up. I checked the fuse and its good. I plugged the relay in without disconnecting the battery.
Review the circuit again:
1- The fact that you jump 30 and 87 and the Air Pump runs proves that:
* Fuse 107 is OK and Air Pump is OK.
2- The "control circuit": is fuse 31 OK?
3- Lastly, does the DME send out signal via pin labeled "X60004".
4- Also check the fuse for the "Secondary air pump valve" too.
5- Is the Secondary air pump valve working?
PS: Maybe you should try the SAS Delete and forget about this whole SAS thingy (see my other thread on ideas how to do a SAS Delete!):
