Bimmerfest - BMW Forums - View Single Post - 04 3.0i diff oil
Old 09-10-2013, 02:23 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Originally Posted by s14DK View Post
thanks for the reply. so those above fluids are safe for 04+ x5 with xdrive correct?
For the diffs themselves (front/rear), yes. For the transfer case oil, you need something else. Go here:
http://www.ecstuning.com/News/BMW_XD...erviceKit_E53/
No idea what the transmission itself uses. BMW changed fluids several times throughout the life of the E53. My 01 used Texaco ETL8072B, which is made of unobtanium. I changed the trans fluid/filter and cleaned the pan about 15k miles ago (at 110k) and used Valvoline Maxlife Dex/Merc. No issues and it shifts fine; Valvoline's spec says it is compatible with Texaco ETL8072B.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
