Bimmerfest - BMW Forums - View Single Post - 04 3.0i diff oil
Old 09-10-2013, 06:48 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Diff oils are the same for E53 models as far as I can tell. If I were towing alot, i might step up to 75w-140 GL5.
The transfer case uses different oil; non XDrive transfer cases in early X5s use ATF. The XDrive models use a different oil, it's a straight 75w GL4 gear oil.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
