Old 09-13-2013, 08:47 PM
RSimms RSimms is offline
Mein Auto: 2001E-53
OK X5 Fans I just had to send a quick reply to let you know that I fixed the door issue. when I took it apart it was St. Louis crazy cold and a few of the well engineered plastic parts cracked and broke. One of the parts that broke was the holding clip for the p-bus wiring. long story short the p-bus will go into the socket both ways. YUP BOTH WAYS!!! If you install it the way it looks to puzzle you will get the same problems I encountered, Pass door switch will operate the window anytime, no mirror adjust or mirror heat, no central locking on pass door, no window operation at driver switch for pass door. hope this helps.....
