Bimmerfest - BMW Forums - View Single Post - successful DSP integration of aftermarket head unit!
Old 09-20-2013, 11:49 AM
ryan04 ryan04 is offline
Mein Auto: X5
So these are the wires i conected.
Connect pin 16 from the round pin plug - - with the wire from pin 4 on the Big AMP Plug
Connect pin 9 from the round pin plug - - with the wire from pin 8 on the Big Amp Plug
Connect pin 15 from the round pin plug - - with the wire from pin 15 on the Big Amp Plug
Connect pin 5 from the round pin plug - - with pin hole 5 on the DB25 plug
Connect pin 7 from the round pin plug - - with the IBUS wire on the smaller plug on the amp (should be white with yellow spots)
This is the wiring for the 17 pin, so i'll try and find the 40 pin wiring diagram for your radio so you can locate these wires to connect to.
