Bimmerfest - BMW Forums - View Single Post - First Bimmer Problem.. Engine Failsafe Prog
Old 10-20-2013, 07:06 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Originally Posted by Bim540 View Post
I can't find any fuses. I must be missing something obvious here..
You don't need to remove the DME, just take the top cover off the DME box.
The 5 fuses are located at the back of the DME box, near the firewall.
The first connector in your first post is the cam position sensor. The t-stat wires run right below the cam sensor wire.
