Bimmerfest - BMW Forums - View Single Post - BMW E60, 545i N62, Engine Removal, Rebuild, Installation
Old 10-27-2013, 07:16 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
There she is
Got everything cleaned up
Had to move the old engine out to a covered space where the new one is, lawn mower did the trick
Not a great work space but better than nothing
I ended up spinning it 180* so it was right beside the other engine, then covering both with a drop sheet of plastic that painters use then put weights around the perimeter of it to hold it down. Should do the trick. I need to go buy another engine stand and some bolts long enough to use to mount it on the stand--I'm not sure the engine stand I have is big enough to not tip over with one of these engines on it but guess we'll see
