Old 11-09-2013, 12:22 PM
Alika808 Alika808 is online now
Mein Auto: X5/330/Range Rover HSE
Seems the radio is bad. There's a feature of the radio that it will turn on without the key in the ignition key at position 1 for at least 20 minutes then turn off. While the ignition switch to off, try to press and hold the volume knob for a couple minutes and I hope it will reset the radio. If didn't works, try to press and hold again while the ignition key in position 1.
