Old 11-16-2013, 04:22 PM
sunny43.5 sunny43.5 is offline
Mein Auto: Sorry VW,s
Hi again I suspect that there is something else that is wrong maybe there is somethng in the tracks because as you say it holds up so that would indicate a problem have you tried some lubrication I recommend white lithium grease it is in a spray can , shake well before use open the roof right back and spray the tracks with a good dose run the roof a few times maybe once the roof is close and tilted spray some in behind the mechanisms from outside at the rear of the glass see if that seems to help beyond that I cannot offer much other information good luck . Howard
