Old 09-07-2004, 10:15 AM
GreatDisappoint GreatDisappoint is offline
Mein Auto: 2004 BMWi Auto Trans
Thank you for the apology.
Originally Posted by vatkens
Iím with BMW of North America, LLC. Iím sorry to read about this problem with your transmission. If you and your BMW center need our assistance, please phone us at (800) 831-1117, and mention Reference #200425100234 so that we can help you more efficiently. If you prefer, you can email us through the Ownersí Circle at www.bmwusa.com.
THANK YOU FOR YOUR APOLOGY.
HOWEVER, I AM NOT SURE WHY BMW NA POSTS THESE 'SORRY NOTES'
ON THE VARIOUS BMW FORUM SITES. ONE MIGHT READ IT AND HAVE
THE IMPRESSION THAT BMW NA WILL DO SOMETHING ABOUT IT.
YET, WHEN A BMW OWNER WITH A TECHNICAL PROBLEM LIKE MINE,
CALLS (800) 831-1117, ALL THAT ONE IS TOLD IS THAT "CUSTOMER SERVICE"
IS NOT TECHNICALLY TRAINED, AND TO TAKE THE VEHICLE BACK TO THE
SERVICE FACILITY; AFTER I INFORMED BMW NA "CUSTOMER SERVICE",
THAT THE SERVICE FACILITY REPEATEDLY STATED THAT THE VEHICLE'S
CONDITION AS DESCRIBED WAS "NORMAL," BMW NA STATED THAT IF
THEY SAY ITS NORMAL, IT MUST BE NORMAL SINCE BMW CUSTOMER
SERVICE IS NOT TECHNICALLY TRAINED.
HOWEVER, IT IS CLEAR FROM THE ROAD TESTS CONDUCTED
BY MOTOR TREND AND EDMUNDS THAT MY PROBLEM IS NOT
"NORMAL," NOR ISOLATED:
August 2004 Motor Trend
http://motortrend.com/roadtests/lux...sts/index3.html
Executive Privilege Road Test: 2004 BMW 545i vs. 2005 Cadillac STS
Variability is no problem, though, when it comes to BMW's 4.4-liter V-8. The Valvetronic engine deals with the airflow restriction of the throttle plate by eliminating it, instead controlling the amount of air ingested by the cylinders by varying valve lift electronically. Stepless variable valve timing for intake and exhaust camshafts and a fully variable intake manifold contribute to a broad, fat torque curve. Output is up, too, 35 horsepower over the previous, non-Valvetronic 4.4-liter engine. This new V-8 feels more powerful than its 325-horse rating might suggest. Part of that credit goes to the 545i's ZF six-speed automatic transmission; first gear is particularly short and gives the engine tremendous torque multiplication for launching off the line at a stoplight. There never seems to be any shortage of gear ratios for the transmission to apply to a given driving situation.
And there in lies another annoyance. One editor noted, "In brisk (but not wide-open throttle) acceleration, the engine seems to lunge from gear to gear, like a chained Rottweiler." Following a line of cars in traffic can prove difficult as well. Under semihard braking, the transmission aggressively forces downshifts, slowing the car unnaturally even after the driver has lifted off the brake pedal as the traffic begins to move again. To reduce the excessive retardation, the driver must step on the accelerator, initiating another forward lunge. Concluded one writer, "BMW needs to work on its throttle tip-in calibration and transmission phasing." Added another, "It's so hard to be smooth, especially at low speeds. Starting and stopping often come off abrupt, no matter how careful you are with the controls."
Paragraph FROM EDMUNDS:
http://www.edmunds.com/new/2004/bmw...rticleId=102584
The driving experience ranged from irritating to exhilarating. Irritation came quickly in low-speed traffic, as the drivetrain responded unpredictably to accelerator pedal input. Too little pressure and the sedan would move out sluggishly. Too much and it would surge forth, leaving the driver to rein it in before it snuggled up to an SUV's rear bumper. The area between these extremes often eluded our editors and made the car a pain to drive at rush hour. In addition, one editor noted that the transmission tended to hang onto first gear too long in these situations ó eliciting more thrust than you really want when slogging from stoplight to stoplight. Another observed that when slowing in traffic, the transmission always seemed to be shuffling through the gears, often supplementing the driver's braking efforts with more engine braking than desired.
A REVIEW OF THE OTHER POSTINGS AT
http://www.bimmerfest.com/forums/showthread.php?t=69842
DISCLOSES THAT THE ABOVE IS NOT AN ISOLATED PROBLEM.
