Deactivating an option
79K views 34 replies 18 participants last post by  EkofabBMW
#1 ·
I have an i3 (IO1) and have just today been able to code quite a few options successfully and it's brilliant - thanks to this forum.
The only other thing I want to do is permanently disable a feature of the car called the "Acoustic Pedestrian Warning" - which is a device that just emits a noisy drone so that pedestrians know there's a car nearby which you can understand is annoying. This is listed in the Vehicle Order FA as 4U9 PEDESTRIAN_ACOUSTIC_WARNING and I've tried removing 4U9 from the SALAPA elements and re-writing this to the car.
The device remains active and what I'm sure is the relevant ECU in the coding menu (VGC) is still present. Sadly, there are no options in there that seem to shut it off. If I physically disconnect the unit, the cars shows an error "Acoustic Pedestrian Warning Fault".
Can anyone shed any light as to how I should attempt to retro-un-fit this module?
#3 ·
Forgive me for not being 100% on the terminology - still learning here! After performing the "Write FA FP" step and confirming that 4U9 is no longer present, I go back to perform FDL coding and the VGC is still listed under the SVT > ECUs hierarchy and I'm still able to code it.
I was hoping that removing the entry from FA would allow me to deactivate the module - or at least for me to disconnect it without a fault code.
To clarify: the VGC ECU object definitely contains all the settings for this module and the 4U9 reference is definitely concerning the same device, but it's just an assumption that this is where I would disable it.
None of the settings available through FDL coding allow me to turn it off.
#4 ·
With modified FA activated, VO Code (Right-Click on ECU and select Code) VCG and ICM if you have one.
#5 · (Edited)
Hello!
In an I8 you can switch off the pedestrian warning in the head-unit. So it could be the easiest way to search for this entry into the Head-Unit to activate the check-box. Only an idea.
If you have written the VO into the car you have to mark the VGC (the folder himself, not the cafd) and press code. Only after this procedure the ECU will be coded according to the changes in the VO.
CU Oliver
#7 ·
So I've right-clicked and hit "code" on the VSG ECU and the device is still active. I have no ICM listed so I'm thinking I'd need to work out whatever my equivalent is. Tried ICAM as it's similar but turns out to be camera-related. Also tried ACSM2 as it's safety related but no effect.
Any other suggestions?
#9 ·
I have the oposite situation. I have the 4u9 option in salapa elements but ir doesnt work. I think my i3 has all hardware needed but doesnt work. Can anybody help me? How it works. How detect the car to pedestrian? By pdc or by kafas cam maybe. BMW dealer told me they dont know why it doesnt work. Thank you for your help.
#11 · (Edited)
Hi,
I have succesfully removed teh 8TF code from VA, recode all ECUs... but I still see Pedestrian error on Dashboard and CIC display... when I check error by ISTA, I can see this:
930B11 Pedestrian protection sensor (optical fibre):Coding data does not match equipment
How is it possible, that the car know about this sensor, when its removed from VA? other bonnets pedestrian sensors are not visible anymore...
We have broken the main Pedestrian sensor as on picture, thats the reason why we have removed it from VA.
There is no more option, which I can remove from VA. So I guess I have to disable this sensor in some ECU - which one? VCG or ICM? which atributte?
I guess this optical sensor has nothing to do with MOST circuit , right?
Please help me with this error. Thanks
//edit:
obviously I have to change some attribute in CAS:
since we are missing ACC radar installed, therefore there are errors in ICM
Low refrigerant = ACSM error
Fuel Low presure sensor = DME
Therefore CAS is the ECU, which I have to modify...but not sure which attribute... :/
#13 ·
pedestrian warning is probably fine... its detecting by cafas camera... but pedestrian protection is thing what you dont wanna have... when you hit somebody..your bonnet will blow up :D and BMW will charge at least couple thousands for recode...etc...
But i dont understand, why , when I removed the 8TF from FA, and code VO all ECUs , its complaing regarding the Optical sensor :(
#25 · (Edited)
Hello, I have exactly the same problem on my f11 2010, i deleted 8tf option from vo, code all car (I selectionned all ecu and I clik «Code») , then I unplug fgs connector (the pss sensor is still pluged)
After this, I have 2 error :
-930BC1 : FGS security sensor error plausibility
- 930B11 Pedestrian protection sensor (optical fibre):Coding data does not match equipment
I delete 8tf from vo i don't understand why there are this error
#33 ·
Any updates on this? I have the following errors after minor collision. I reconnected the fibre optic but it continues to throw up the error.
930B1A: FGS_SB pedestrian protection sensor defective
930B12: FGS_SB pedestrian protection sensor sends error
I could do with a simple walk-through solution using ista p for example. My f11 has front parking sensors.
