I have an i3 (IO1) and have just today been able to code quite a few options successfully and it's brilliant - thanks to this forum.
The only other thing I want to do is permanently disable a feature of the car called the "Acoustic Pedestrian Warning" - which is a device that just emits a noisy drone so that pedestrians know there's a car nearby which you can understand is annoying. This is listed in the Vehicle Order FA as 4U9 PEDESTRIAN_ACOUSTIC_WARNING and I've tried removing 4U9 from the SALAPA elements and re-writing this to the car.
The device remains active and what I'm sure is the relevant ECU in the coding menu (VGC) is still present. Sadly, there are no options in there that seem to shut it off. If I physically disconnect the unit, the cars shows an error "Acoustic Pedestrian Warning Fault".
Can anyone shed any light as to how I should attempt to retro-un-fit this module?
