Definite improvement over the "bottle caps". With that new tire size the diameter is smaller than stock so your speedometer is going to show you going about 7% faster than you actually are.
I was putting bebe back together this afternoon and realized that the vacuum actuator for the DISA valve is shot. Apparently the diaphragm is busted, because it has no resistance to a vacuum or pressure applied to the vac port.
It's #6 in this drawing:
I hate to put it back together without a working actuator, because it's a PITA to get to. The manifold would have to come back off again, which is an awful job in itself. The DISA valve really does make a difference, although it will work without it and the vacuum line plugged. New from various vendors the price is anywhere from $70 (ECS) to $89 (Pelican). :yikes: :wow:
i *might* have one from the ti. it's no longer going to be of use in its current state, and am seriously have nasty thought of what to do with this little hatchback at the current moment....:angel:
but it ain't gonna be sparkle green anymore!!:nono:
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
