Do E34s have a door ajar message/chime? Mine doesn't and I never thought anything of it. I only get "KEY IN IGNITION" if I open the door with the car off and the key in.
The volts lost through bad grounds cause all sorts of problems with the computers/electronic controlers throughout the BMW ranges. Fixing them often makes the problems go away. Grounds combined with corroded terminals seem to cause more problems than anything else that comes up in the forums.
So i recently had a bit of water enter through the sunroof due to a blocked drain. All issues are fixed now although the only problem that remains is that My "door open" chime keeps ringing everytimr I stop in traffac and continue to drive. its so annoying, as you would imagine the interior lights stay on the entire time as the "computer" thinks there is an open door. So I have turned the interior lights off until I get it sorted. So if you think its the grounds, please tell me where to look and how to fix ??
Do this. Remove the B-pillar cover. Behind where the seatbelt runs, there is a crevice that you can reach up into to get to the wires that control the door jamb switch. Short them together and see if the problem goes away.
If the messages do go away, you know the problem is at the switch.
Well, now my auxillary water pump just went out, so now to get one of those.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
