You need to have the proper compressor in order to convert without replacing the compressor. The seals will not hold the smaller R-134a molecules. Check the partnumber on your compressor and see if it is an R-134a compatible compressor.
I've successfully re-gassed many r12 systems with R134 and PAG oil using the original compressor and seals. R134 is a smaller molecule but the leakage issue is very nominal, perhaps a little more gas every couple of years. Tree huggers fire away.
This. I filled the stock set up with R134 about 3-4 years ago...still works fine...if any leakage has occurred, I am sure it's not worth worrying about.
Thanks again for the answer. I think I'll do that. Put 134 and live with the leaks. MeanM50, did you check the part number of the compressor or didn't bother al all??
I bought a proper valve and was able to put the new gas in it. And it works.
One minor thing is that I have cold air blowing in most of the vents except for the feet.
Found out that the AUTO buttons doesn't stay in. Well.
Best regards and thanks for the help
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
