Bluetooth Probs
2K views 9 replies 3 participants last post by  Alex Baumann
#1 ·
Hi,
Just wondering if anyone can help me... I have had my X5 for 3mths and have used a Nokia 6310i with the bluetooth phone prep and it worked fine. I have now just purchased a Nokia 6600 and cannot connect it to the car?? I have been told by Nokia that it is a new sort of bluetooth that may not be able to connect with the car. Has anyone got any advice on how it may work?
#2 ·
Browny said:
Hi,
I also have a 6310i that connects without issue, I must admit i've not come across a new type of bluetooth, I assumed it to be an industrial standard.
What happens when you try and do the pairing ?
Jon
#4 · (Edited)
Browny said:
pairing worked fine, the same as 6310i, it said pairing successful. It will ring through the the speakers but when i answer it cuts out and goes striaght to the handset.. weird and very frustrating...!
I Fear you are not alone, check this out
http://www.expansys.com/forumthread.asp?code=105822&thread=86
also got this here http://www.mdload.com/bluetooth/
Which phones are compatible?
Fully compatible
Nokia 6310
Nokia 6310i
Nokia 8910
Nokia 8910i
Ericsson T39m
Partly compatible
T68m/T68i. The phonebook does not automatically transfer at pairing or on subsequent connections.
Siemens S55. The phonebook only transfers on initial pairing.
Not compatible (unusable with car kit)
SonyEricsson P800 (although a software upgrade is supposed to rectify this)
Nokia 3650 (supports "handsfree" only)
Nokia 6600 (supports "handsfree" only)
Nokia 7600 (supports "handsfree" only)
Nokia N-Gage (supports "handsfree" only)
Nokia 7650 (supports data only)
NEC e606 (data only)
NEC e808 (data only)
Motorola A830 (data only)
Older Nokias via Bluetooth Battery (data only)
Palm via Bluetooth Card (data only)
Jon
#5 ·
thanks for the bad news!!! oh on your 6310i did you get the sms to work??
Fully compatible
Nokia 6310
Nokia 6310i
Nokia 8910
Nokia 8910i
Ericsson T39m
Partly compatible
Jon
#6 ·
No, it comes up with not supported or something like that. Any solution or was that the new phone idea ?
Nb.
I have a multisim setup so I keep the 6310 in the car and just switch nominated sim. If your with Vodafone, you might want to look at that so your 6310 is the car phone and your new one is the main phone.
Vodafone charge about 5.50 per month for a multsim.
Have to do a manual switch though as voice control doesn't seem to understand "hash"
You need to nominate to accept inbound calls to the second phone, but can always make outgoing even whilst on a call via the other phone.
#9 ·
Alex Baumann said:
Unfortunately, the SMS is still not supported.
Hi Alex
Is the SMS supported via any phone ?
