F001-13-03-501
F010-13-03-501
F020-13-03-501
F025-13-03-501
----------------------------------------------- NOTE: The 49.0 PSdZData release marks the end-of-life for E-Sys 3.18.4. The changes made to the F20 PSdZData in 48.3 are now across the board in the 49.0 PSdZData. Old Patch / Tokens will no longer work for any chassis.
Could you please provide me with PSDZDATA 49.3? It would greatly be appreciated. Also do you know where I can get a copy of ISTA/D and ISTA/P? 2.36.9 and 2.49.3? I would like to use it with my new ICOM
The reason I ask is because I just picked up a 04/2013 F30 and wanted to do some coding which I am hoping 49.3 PSDZDATA files will help with. I have a version of INPA but does not have F30 support only F01 but it is very limited to what information I can see. I read that I need new scripts for my INPA in order to scan my F30. Do you have a solution for me? I want to be able to scan my vehicle for faults. I have ISTA/D 2.35.12 however it does not recognize my VIN. Is there any other software I can use that you know of? or a more complete version of INPA with F30 support? I look forward to your reply. Thank you for all the support so far.
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select fs_lesen_funktional
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional will only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
Is it possible to change vin nr by e-sys in my f10, because i bought a used emf and i have a problem. I would be grateful if u send me a solution and "how to" make a working 3.22.5 and 49.1
You would need to flash the firmware on used ECU to write VIN to it. Problem is, to flash, you need to know the I-Level Shipment of the Donor Car, other wise E-Sys won't properly know which ECU Part Number it is dealing with.
There`s a possibility that the ecu was "cleard" inside the eeprom does it change the matter? but i think it was done by changing vin to "000000000000000" and that`s all. I think i will see in e-sys what`s up with this ecu. Can you give me some advices, i can go to bmw dealr as well but i don`t know the history of last vin number and there`s a problem because dealer contacts nypd immediatly if there`S a problem. Can u send me links to working esys and psdz and est. by the way everything works fine with the brake but the yellow icon blinks about the parking brake fault.
If the ECU EEPROM VIN has been blanked, which is usually not the case, then it should just require injecting CAFD and VO Coding ECU. During the VO Coding, VIN will be written.
Hi Shawn,
I have 3.22.5 and 49.2 and i need 49.3 cafd files to upgrade 49.2 to 49.3 because i got cafd_00000794-004_228_010 file not found error. Can you send the link for 49.3 additional files to upgrade 49.2. Thanks.
Hi Shawn,
i dont like it ! it is off now
if you will turn left and you must brake and just in time the engine is off it takes 2 seconds until the car starts
absolut bad
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
