48.3 vs. 49.0 PSdZData CAFD Changes - E-Sys 3.18.4 End of Life - & 49.1 Changes
123K views 1K replies 301 participants last post by  shawnsheridan
#1 · (Edited)
FYI. The difference from 48.3 to 49.0 for the CAFD folder is 56 added and none removed:
Left base folder: C:\48.3_PSdZData
Right base folder: C:\49.0_PSdZData
Left Orphan Files (0)
Right Orphan Files (56)
cafd_0000000f.caf.005_024_225
cafd_000000b5.caf.010_004_004
cafd_000000b6.caf.010_004_004
cafd_000000c9.caf.003_000_000
cafd_000000f9.caf.007_003_031
cafd_000000f9.caf.007_005_003
cafd_000000f9.caf.007_006_008
cafd_00000a07.caf.002_013_002
cafd_00000a48.caf.000_004_009
cafd_00000b0a.caf.000_024_001
cafd_00000b52.caf.002_010_000
cafd_00000c18.caf.013_064_004
cafd_00000ce2.caf.003_001_017
cafd_00000ddd.caf.003_001_017
cafd_00000ded.caf.002_002_007
cafd_00000e69.caf.002_002_004
cafd_00000e69.caf.002_002_005
cafd_00000ed9.caf.002_000_008
cafd_00000fa2.caf.001_004_000
cafd_000001a7.caf.000_012_004
cafd_000007a1.caf.005_028_006
cafd_000007c3.caf.011_000_000
cafd_000007c8.caf.006_008_004
cafd_000007c8.caf.006_009_004
cafd_000008a6.caf.001_005_000
cafd_0000012f.caf.012_006_021
cafd_0000012f.caf.012_006_022
cafd_00000014.caf.004_055_014
cafd_00000014.caf.004_055_214
cafd_00000018.caf.004_010_001
cafd_0000029b.caf.000_008_001
cafd_00000044.caf.008_005_000
cafd_0000067b.caf.002_003_142
cafd_00000069.caf.009_001_004
cafd_00000069.caf.009_001_006
cafd_0000090a.caf.004_001_017
cafd_00000092.caf.004_002_027
cafd_0000106d.caf.012_006_016
cafd_0000124f.caf.000_004_004
cafd_0000157f.caf.008_000_001
cafd_00000163.caf.007_001_009
cafd_00000163.caf.007_001_031
cafd_00000223.caf.013_008_004
cafd_00000286.caf.001_006_000
cafd_00000552.caf.001_029_001
cafd_00000553.caf.001_038_001
cafd_00000694.caf.003_003_042
cafd_00000721.caf.003_006_000
cafd_00000760.caf.006_000_051
cafd_00000794.caf.004_228_005
cafd_00000893.caf.006_050_012
cafd_00000896.caf.006_023_003
cafd_00000912.caf.003_007_009
cafd_00000913.caf.003_004_003
cafd_00001016.caf.001_003_000
cafd_00001060.caf.003_001_003
ISTA/P 2.49.0 Fxx Integration Levels
F001-13-03-501
F010-13-03-501
F020-13-03-501
F025-13-03-501
NOTE: The 49.0 PSdZData release marks the end-of-life for E-Sys 3.18.4. The changes made to the F20 PSdZData in 48.3 are now across the board in the 49.0 PSdZData. Old Patch / Tokens will no longer work for any chassis.
To use the 49.0 PSdZData, you must upgrade.
See less See more
#364 ·
Hi Shawn,
Could you please provide me with PSDZDATA 49.3? It would greatly be appreciated. Also do you know where I can get a copy of ISTA/D and ISTA/P? 2.36.9 and 2.49.3? I would like to use it with my new ICOM :)
PM sent.
I can't help you though with ISTA/D & ISTA/P, as I don't use them. Incidentally though, ISTA/D is now at 2.37.3.
#365 ·
Thanks for everything Shawn,
The reason I ask is because I just picked up a 04/2013 F30 and wanted to do some coding which I am hoping 49.3 PSDZDATA files will help with. I have a version of INPA but does not have F30 support only F01 but it is very limited to what information I can see. I read that I need new scripts for my INPA in order to scan my F30. Do you have a solution for me? I want to be able to scan my vehicle for faults. I have ISTA/D 2.35.12 however it does not recognize my VIN. Is there any other software I can use that you know of? or a more complete version of INPA with F30 support? I look forward to your reply. Thank you for all the support so far.
#366 ·
Read or Clear Fault Codes:
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select fs_lesen_funktional
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional will only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
#375 ·
#377 ·
Hi Shawn!
Is it possible to change vin nr by e-sys in my f10, because i bought a used emf and i have a problem. I would be grateful if u send me a solution and "how to" make a working 3.22.5 and 49.1
You would need to flash the firmware on used ECU to write VIN to it. Problem is, to flash, you need to know the I-Level Shipment of the Donor Car, other wise E-Sys won't properly know which ECU Part Number it is dealing with.
#378 · (Edited)
esys 3.22.5
Hi shawn!
There`s a possibility that the ecu was "cleard" inside the eeprom does it change the matter? but i think it was done by changing vin to "000000000000000" and that`s all. I think i will see in e-sys what`s up with this ecu. Can you give me some advices, i can go to bmw dealr as well but i don`t know the history of last vin number and there`s a problem because dealer contacts nypd:) immediatly if there`S a problem. Can u send me links to working esys and psdz and est. by the way everything works fine with the brake but the yellow icon blinks about the parking brake fault.
#379 ·
Hi shawn!
If the ECU EEPROM VIN has been blanked, which is usually not the case, then it should just require injecting CAFD and VO Coding ECU. During the VO Coding, VIN will be written.
#381 ·
Hi shawn
That looks possible. Can ypmleasese pm me pm a working version for my 2011 f10 would be grateful.
Regards,
Greg
PM sent.
#383 ·
What info?
Without knowing what chassis you have, its hard to even guess.
#390 ·
Hi Shawn,
I have 3.22.5 and 49.2 and i need 49.3 cafd files to upgrade 49.2 to 49.3 because i got cafd_00000794-004_228_010 file not found error. Can you send the link for 49.3 additional files to upgrade 49.2. Thanks.
No, you can not add 49.3 CAFD's to older PSdZData library. They need the full 49.3 PSdZData.
PM sent.
#395 ·
Hi
Can you please send the password for the 49.4 psdzdata.rar files
Thanks Tackerkratzke
PS. Is it possible that the Engine (M5F10) dismatch after programming Auto Start stop off.
Too much fuel in Kat. He burned out!
550i / M5 does not come with ASS (Auto Start / Stop), as it is not available on V8 Motor.
PM sent.
#405 ·
Shawn do you think you can pm me the place to download
full 49.3 pack for 3.22.5
and password for it?....
i been trying to code my Hong Kong version F07, but the code did not stick...
it just revert back to default every time
PM sent.
