Actually, that code was discovered by my Korean brother, mongsiri. All credit goes to him.
D1-D8 to go along with S1-S7 would be nice, but I did not see anything in EGS for that. Although since my car seldom operates in that girly mode, I admittedly did not give searching for that code its due diligence.
Shawn,
Nice one!! I just went out and did that one in just a few minutes. Thanks to mongsiri for expanding the state of the art and to you for passing it on.
It doesn't work, I checked twice. Year 2010/04. Automatic transmission, without paddles.
There is:
EGS / 3000 Applikation / Sportschalter_alt (Not just Sportschalter) = aktiv / Werte=01
but not works.:bawling:
Yes, please do. I am trying to see if consistently both are required or if only Sportschalter_alt = aktiv is required, and if it is the later, why in some cases both are necessary. Thanks.
I'm sill trying to figure out how to get the S1-S7 to display when I put the tranny into sport mode via the adaptive driving toggle. If anyone figures that one out please let me know.
Drivetrain is effected (if selected). In my case the tranny absolutely goes into sport (no 8th gear) mode since I have drivetrain selected to be controlled. Whether I pop the shifter to the left or toggle the the switch to sport mode, the tranny reacts the same (of course I have to either move the shifter or tap the paddles if I want to force a gear change but other than that the tranny reacts the exact same.
I'm going to do a test run later tonight where I'll note the gear changes, etc. when I put the tranny in sport via the toggle and via the shifter. I'm ivory pure (99.44%) sure the tranny is behaving the same in both those modes. If it was not then there would need to be three distinct operating modes (besides manual shifting M1-M7): normal; sport (induced by moving the shifter to the left); and sport (induced via the adaptive drive toggle).
Sorry, I should have mentioned above Throttle too. My understanding is that the Standard 8 Speed Auto DEC Sport Mode with DHP adjusts Steering, Throttle, and Suspension. Without DHP, I think it is just Steering and Throttle. In either case, for transmission adjustment, you need SAT.
I commented earlier that it was easy to make the change but unfortunately I was not able to test it at the time (wife's car). When I did, I still only got DS. I then tried change both items, and still no change to S1-S7. I have a 2013 X3 28i with no M-Sport, SAV, or paddle shifters (again, wife's car).
I did my ride tonight and I gotta tell ya, there is ) difference in the behavior of the tranny between popping the shifter to the left ot togglinh to sport mode using the adaptive drive switch (with drivetrain turned on in the settings). The transmission acts identically in both settings. So my question is if it goes into the same mode why doesn't BMW display the S1-S7 when we are in "sport" mode (again, providing you have drivetrain effected in the settings)? BTW, if I slide the shifter to the left when I'm already in "sport" mode nothing changes (except the ability to manually change the gears).
I hear you, but I just can't imagine that BMW would have the DEC Sport Mode, and the Gear DS Mode both adjusting the transmission shift points. :dunno:
Thanks Shawn. I appreciate the effort to follow up on my understanding. Now my question goes back to: "Why doesn't BMW have the S1-S7 displayed when you enter in sport mode (transmission) when you do it via the toggle?" I'll keep looking for a coding answer but I suspect there may be triggered by a relay on the shifter instead of the tranny itself.
I don't understand, do we need a special tool to do the coding? Or we can just use a software installed on the computer to do it?
What is needed actually?
Hi Shawn,
Thank you so much for the quick reply. I really appreciate it.
Anyway, do you know where i can buy the enet cables? I would love to buy them for me to try out coding myself.
Also, do you know where can i download the e sys application?
Thanks again.
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
