I think the LED array is integral to the panel. The incandescent lamps are obviously replaceable but if one or more LEDs have quit, I seem to recall reading you need to replace the whole socket panel.
nope not replaceable, I just went thru the same thing with my 07 335I, the whole unit has to be replaced, once I replaced it I mangled the old unit to see if it is, and its not, I cut it apart with a cut off wheel just to see what it looked like on the inside, its got a circuit panel board inside too, thats probably what died. I have also noticed that the other lamps, only one seems to be replaceable the rest I could not pull them free of the board to use as spares.
go thru bmw parts of south atlanta, I savde about 60 buck from what the local BMW place wanted, and I just ordered the upper strut mounts and saved about 60 dollars each on them
Hondo
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
