BMW E90 LCI Rear Indicator Lights
4K views 6 replies 3 participants last post by  hondo402000
#1 ·
question (my freinds' car)
How do I relace rear LED Indicator light BULB or Panel ? (2009 LCI E90 Model)
#2 ·
1. Open trunk.
2. Pry/pop out trunk lining access panel behind light cluster.
3. Remove nuts (8mm IIRC).
4. Remove & disconnect cluster.
#4 ·
I think the LED array is integral to the panel. The incandescent lamps are obviously replaceable but if one or more LEDs have quit, I seem to recall reading you need to replace the whole socket panel.
#5 ·
nope not replaceable, I just went thru the same thing with my 07 335I, the whole unit has to be replaced, once I replaced it I mangled the old unit to see if it is, and its not, I cut it apart with a cut off wheel just to see what it looked like on the inside, its got a circuit panel board inside too, thats probably what died. I have also noticed that the other lamps, only one seems to be replaceable the rest I could not pull them free of the board to use as spares.
Hondo
