Correct & complete OEM aux Retrofit install
309K views 438 replies 126 participants last post by  PAPER
#1 · (Edited)
I made these 2 videos for those of you who have a FaceLift Ask Unit & FaceLift MMI
that would like to do the Auxiliary plug Mod in your car . I also made them cause
some 1 accused me of taking credit for there work . There are 2 members on here
that can confirm I have had the Auxiliary feature in my 2002 745LI for just under
4 MONTHS . They have Both been in my car on several different occasions & have
seen it with there own eye's a few month's back .
Those 2 members are =
Rookie2008 ( real name is MARK )
http://www.bimmerfest.com/forums/member.php?u=225734
B7M4W5 (real name is CARLOS )
http://www.bimmerfest.com/forums/member.php?u=260565
DO AT YOUR OWN RISK
I AM NOT RESPONSIBLE FOR ANY DAMAGE YOU CAUSE TO YOUR CARS .
Published on Jul 28, 2012
FOR ALL OF YOU PRIVATE MESSAGING ME , IT IS EASIER IF YOU JUST LEAVE
ME A # I CAN CALL YOU AT INSTEAD OF AN EMAIL ADDRESS .
THE PRICE ON THIS MOD DEPENDS ON WHAT YOU PAY FOR THE PARTS NEEDED .
THESE PARTS ARE NEEDED FOR THESE YEARS OF YOUR E65 E66 =
1 = ASK UNIT IS NEEDED FROM = ( 02 TO EARLY 06 )
2 = MMI SCREEN IS NEEDED FROM = ( 02 TO 05 )
3 = AUX CABLE NEEDED ALL YEARS NOT EQUIPPED WITH IT
4 = AT TUNER NEEDED = ( WHEN APPLICABLE 02 TO EARLY 06 )
& YES YOU STILL HAVE TO HAVE THE AUX FEATURE CODED
SO IT SHOWS UP ON YOUR SCREEN . THE DEALER WILL NOT
CODE THE AUX FEATURE ON YOUR CAR . YOU WILL NEED TO
FIND SOMEONE TO CODE IT FOR YOU , OR YOU CAN LEARN TO
CODE IT YOURSELF ...
=== READ CAREFULLY ===
BE SURE TO CHECK THE BUILD DATE ON PARTS &
MAKE SURE THEY ARE FROM A CAR BUILT IN LATE 06
, 07 , 08
IF YOU HAVE AN 02 TO 05 YOU WOULD NEED
1 = MMI SCREEN ( BUILD DATE FROM 06 UP T0 08 )
2 = ASK UNIT / CD PLAYER ( BUILD DATE 07 UP 08 )
3 = AT/TUNER ( BUILD DATE 06 UP 08 )
FOR THOSE OF YOU WITH AN EARLY BUILD DATE 06 .
YOU WOULD NEED
1 = ASK UNIT/CD PLAYER ( BUILD DATE 07 TO 08 )
2 = AT TUNER ( WHEN APPLICABLE BUILD DATE LATE 06 TO 08 )
THIS WILL WORK ON ANY 745 OR 750 FROM 2002 TO 2008 AS LONG AS YOU HAVE THE CORRECT PARTS NEEDED ...
YOU WILL STILL NEED TO HAVE THE AUXILIARY FEATURE
CODED ONTO YOUR MMI SCREEN BY SOMEONE WHO CAN DO IT .
PREFERABLY AN EXPERIENCED CODER .
THE DEALER WILL NOT ADD THE AUX FEATURE TO YOUR CAR !!!
PIN POSITIONS =
2 = RIGHT = RED/WHITE
7 = LEFT = BLUE/WHITE
8 = GROUND = BLACK OR WHITE & BROWN
DO AT YOUR OWN RISK
I AM NOT RESPONSIBLE FOR WHAT YOU DO
TO YOUR CAR !!!
PLEASE WATCH BOTH VIDEOS .
http://www.youtube.com/watch?v=s4imynuJ2Oc&feature=channel&list=UL
http://www.youtube.com/watch?v=u9lkxUDMrDk&feature=channel&list=UL
IF YOU CLICK THE SHOW MORE UNDER THE VIDEO , YOU WILL SEE
THE PART # & A LINK TO PURCHASE THE PART ON AMAZON .
LEFT SIDE OF THE PICTURE IS A NON FACELIFT
RIGHT SIDE OF THE PICTURE IS A FACELIFT
See less See more
1
#53 ·
To make it easier for you guys to understand if you have a 06 750 then you can add Aux if you Have a 745 then you need to buy a ask unit from 06 to 08
#55 ·
I do believe the link is posted on here somewhere.
#56 ·
my ask unit was manufactured in early 06 so it doesn't support the AUX function.
i bought an exact same ASK unit on ebay that was manufactured in 07 and will try it out this weekend.
does anybody know if i need to do any type of programing to the new ASK unit or is it just plug and play? (my MMIGT already has the aux option turned on and i can see it in the entertainment menu)
#58 ·
any one know what problem code 1890 on a 745i 2003
I'm not sure why you would come into a topic about radio auxiliary
& ask a question about fault codes ???
here is your answer , & if you have any more questions the search
feature is your friend , Or you can make your own topic .
This topic has nothing to do with fault codes
So please keep your questions out of this topic !!!
P1890 trans control usually caused by low or unusual voltage ,
Also Speed change control linear solenoid valve failure &
Transmission failure .
#59 · (Edited)
Ok i have missed any think
I have AUX showing in my MMI I have removed the ask and plugged the new cable in. I have changed the wiring on the plug to the correct pins. I have not sound out the aux. Also in the MMI I click on AUX and I still see my fm presets on middle screen. Could it be that my car is a 06 even thou it has a facelift the ask will not work. Any way to update the firmware on the ask?
I have checked realoem and the same part number is from 03/05 so it should work unless its software.
#61 ·
Ace you still on that bull****. Get over it or come to cali and deal with paper direct stop wasting space on our site. Ban this fool for keeping this **** going
#64 ·
Ace, I am happy you are on this site. I appreciate all of your efforts and you are if not THEE best, one of THEE best guys on here for info. We need to move on from here. Stopher, Im not sure if this whole thread needs deleting, maybe just the back and forth between Ace and Paper.
#66 ·
Ok not sure what you mean
"aux items not come out "
Are you talking about the auxiliary Feature on
Your MMI screen ???
You must code your MMI , the feature does
Not show up just by adding the auxiliary plug .
You can use NCS to add that feature to your MMI.
Sent from my GT-N7000 using Bimmer App
#68 ·
No prob happy to help out .
When you use NCS you want to read
Your MMI , then look for the line that
Says Aux & set it to aktiv . Then write
It back to the car .
After that you should be all set.
#73 ·
Is this kit compatible with my 2006 760LI
I have trunk NAVI03
dvd changer on trunk
6 cd/mp3 changer at front
1 cd ask
the aux option is not on my menu ( It will show it after you install the cable )
Thank you, your video is very good
No you also need to have your MMI coded
So the auxiliary option shows up on the screen .
#78 ·
This seems like a much cheaper solution if you have a stock 2003 E66. I have an electronics background and can wield a soldering iron like a ninja. You removed the radio from the right c-pilar, then opened it up and tapped in to the line-out from the radio, correct?
:dunno:
If so, I would like to do this. I dont need details on running the Aux to the front. I know about shielding and using a relay/switch to switch between the Aux and Radio. Simple crap like that I can figure out on my own.
:eek:uch:
What I need are pictures to show where to cut the traces and where the signals are. If you have them, will you share?
Contact the OP he lives in your area an I'm sure he would be willing to help you.
#79 ·
bmw e65 aux in
hello paper, thanks for sharing this great work with every one here, my question here is did you have the aux already showing on your screen even before putting the retrofit? in my bmw i have got ( fm.am.cd.cdc.tone) would that cable work for my car? i mean once i connect the cable into the back of my head unit will that aux sign starts to show up automataically on the screen?
greetings all the way from london
#80 ·
No , some coding is needed to add aux to your MMI Screen .
You would need the correct cable & NCS Expert for the coding .
#82 ·
PAPER, I have been trying to find a way to install a AUX port in the car ever since I got it. The only option was to remove the 6 CD Changer and install an iPOD adaptor. And this cost $1200…so I stayed away. But I found your post and WOW great JOB!!!
I have since bought the AUX mod and changed the sequence to 2,7,8 and installed it in my car. The AUX category didn’t come up so I guess I have to use NCS expert and do some programming.
Thanks again!!!
#86 ·
ok let me try to be clearer for you . When you push the I-drive knob
& select Aux , what shows up on the screen ?
Does the Aux volume control show up & can you adjust it ?
Also take a pic of the screen with your phone & post it up so
I can see what is on your screen .
