Um why would you want to do this?? The engine computer systems changed from the e34 to the e39 and it is more difficult to retrofit an e34 into an e39. Why would you want to put an older engine into the car?
The '97-'98 528i's have the M52 engine. In 1999 it changed to the m52-tu which added dual VANOS, DISA valve and other electronic changes. Trying to swap anything other than an M52 will cause more problems than it's worth.
Similar question. I am considering buying a nice '98 528 with a blown motor. I have a M52B28 from a '98 328i that I assume would go in without much trouble or I might want to try finding an M62 which I also assume would fit. Not sure it would mate with the tranny though. It has the 5 speed manual and I think the 540i came with the 6 speed. Anyone know if I can use the M62 on that tranny?
The I6 & V8 e39s not only have different transmissions...but also do NOT share the same front suspension.
The V8 e39s (M62 & M62TU engines) have the old recirculating ball front suspension because there is not enough room in the e39's engine bay design for the updated rack-n-pinion front suspension that the I6 models got.
So installing a BMW V8 in an e39 6 cylinder model would require a complete different front suspension as well as transmission & rear end.
And as someone already mentioned...the easiest replacement engine is the same one being replaced...and in this case it's the M52 engine. If you don't know which BMWs used this engine...a simple internet search (wikipedia for instance) will reveal what other BMW models (and any other car model) used the same M52 engine. This will also include the engines displacement (B28 in this case).
FYI: one must also consider other BMW technology like EWS. One must consider the original DME since it has a coded ISN (individual serial number) that must match the other EWS components in order for the vehicle to start. So swapping in an entire engine & management system from another car can be fraught with issues if the other EWS components aren't brought over with the engine & engine management systems...but this is only an issue if one is not keeping the original engine management system.
It's a bit blasphemous but why not implant a 2jz-gte or an RB26-dett N1 in her since money is no issue? I mean why else ask the question if you have unlimited resources, right? Better yet, throw a Nelson Racing Engine on that hoe and rock 1500WHP!
Not sure how we got off on a tangent about money not being an issue, but if that were the case we certainly wouldn't be discussing this in the e39 forum. Lets face it that is why we are all here.
Thanks for the good technical info. I am closing the deal on the car tomorrow and my plan is to put the M52 from my donor 328i in it. I am told I will have to swap the oil pans but otherwise it should be straightforward. I will use the DME that is already in the car so the EWS should be happy. Will post pics when I get it home.
:rofl: Hey everyone, Im new to this forum and also new into a bimmer. I have a 1996 BMW 528i ever since I got the car I been wanting to make a build (Street/Drift/Track) and swap out the 2.8 engine to a Nissan RB26DET. I was looking around the forum and saw that a Toyota 1JZ/2JZ can be fitted into the E39 chassis but i really want to put in a RB26 in there, you know mix it up a bit. Another thing is that the 528 I have is an automatic :stickpoke . I want to also swap the automatic transmission for a 5 or 6 speed manual that can fit with the RB26DET and still make it all fit in the car at the same time. So if any one can help me ill be really happy. THX
Sorry but it ain't happening. Too many questions asked so that means you don't know what's involved at all. If you have enough money then take it to a shop and have them swap in any engine you want.
I didn't know about this old thread, but I will xref this information into the thread found by typing /swap f3 in the bestlinks ...
- What engine swaps are most recommended (1) (2) (3)
See also:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
I realize this is old thread but one useful bit of information that did not emerge is that the S52 3.8 liter engine from the E36 M3 is a fairly easy swap into the early E39 with the M52 engine and manual transmission. The engine blocks are the same externally and the 5 speed manual transmission is the same in the E39 and M3. The DME (engine computer) would need to be re-flashed with a software load capable of running the S52. This is a vendor I have used that can provide the necessary software:
"It's a bit blasphemous"...If you're thinking of anything besides the same BMW engine, the suggestions about the LS engine is a good one. Both from an engine cost perspective, reliability and availability of a ton of parts. This probably isn't the place to get good info about it though.
If you're seriously thinking about an LS swap, consider the LS3. It's one of the newest and takes to mods very well. Guys run 650HP with stock internals without problems. The other LS, if you can find one, is the LS7. That's the 7.0 liter/427 CI motor, 505HP stock. One of the members, I think on the "other" site, swapped in an LS7 in a 5 Series and loves it. I have a 2008 Corvette with a modded LS3 and it's a friken animal. Starting to digress though...G.L.
As per above, you need to look at other forums that are more focused on engine swaps and the necessary information to go with it all. This forum is very oem orientated! You'll need to do a ton of research yourself to try and understand all that's required and have a nice healthy, read large'ish, bank balance to do it all. This won't be a over the weekend swap, there's a LOT of aspects you need to learn, research and get right prior to purchasing anything.
mda185 - Various japanese engines have been fitted to the E39 and multiple times/instances. They just tend not to show up on this forum. Do take a look around though, there's plenty of E39's with 'interesting' engine swaps etc!
540 Hammer - I've got my eye on importing another American car over here to the UK again, The F150 anniversary edition Harley Davidson was swapped for an Alpina B3S a few years ago, however, it looks like another one will be back on the family driveway today as my bro's driven over to buy another today! not sure if he's actually purchased yet, but he will if it's not an abused example. I want something much smaller and sleeker to match it soon (I hope) so looking at the modern classics like the Challenger and Camaro, perhaps a Corvette z06 ! - I'll just have to hope UK petrol prices remain what we consider 'low' for us !
Dennis, The Challenger is a large car and as such handles like one. Unless you can find one with the SRT package, I wouldn't bother with it. At least go with the SRT, it will get the hell out of it's way. It's not small or sleek though. The SS Camaro is a decent car; handles decently and has good power, nice balance of both. If you can get the Z06, that's a must!! Great power to weight ratio and handles like cars that cost 3-4x's as much. You won't believe it until you drive it. That would be number one, especially if you're seeking smaller and sleeker. Out of all three, the Corvette actually would get the best MPG, IF you keep your foot out of it, BUT good luck with that!!
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
