Is my BMW elergic to water??? I want to write this as short as possible. I had my 1998 540i for just over a year when, in the rain at idle speed and about 5mph, my 8th cylynder blew a hole the size of my fist threw the bottom of the block. 2 weeks later my dad's mechanic(for many years) got a refurbished engine put in. he drove it 2 times and on the second one almost the identical thing happened to him. Same cylynder and everything. this happened 3 more times over the course of 7 months that the car was in the shop. 6 months later after the first signifigant rain of the season; I went to take my car out of the driveway and I got the same rough, feeling I got just before the motor blew before. since then I've started it and let it idle. It sounds fine, maybe a little exhaust leak. when i bring the rpm's up (reving it slightly) when it comes back down it falls to about 400 rpm and stays that way for a bit. I'm scared to drive it and don't know that its worth putting more money into after buying a new motor and front suspention. I've written to BMW and got no responce about a year ago. Any Ideas would be appreciated. Everyone I've talked to can't beleive it and has never seen anything like it
No mods other than wheels. And I have some sort of prob with the ECU in general. I constantly get warnigs for all my lights. I'm in San Jose also, where do you get your work done?
OP - you may want to try another angle with your first few posts if you're looking for help from the members of this forum. I also wouldn't get too peeved if people spell words correctly in consequent posts after your trivial mistake....
Also, please consider what questions you are actually asking - I'm not sure if you prompted anyone to help you with anything other than "Is my car allergic to water?" What kind of ideas are you looking for?
Please provide us with symptoms, codes - well, really anything that would allow us to help you. I also have a hard time believing that your 5 engines all let go without any form of warning and have nothing in common aside from the fact that it was raining, and I would appreciate it if you stop ruining all the used M62s around.
Well thanks for the tips. I dont have all the answers. I don't know the codes and the only symptom I've had was a very low idle then just stops other than that instance its running fine prior. It only happened to me twice. Once moving forward in a parking lot then again in reverse backing out of my drive way. I dont have much to go off of since it happened so fast. Pretty much felt like it was stalling(best way I can describe it). The other times in the shop it was similar, and thats all I know. I asked in this forum with a ridiculous statement because the whole situation is ridiculous and unbelievable. I have no idea what to do or even where to start. I wanna beat it this time rather than have a 6th engine die. The long and the short of it: what could cause that much compression in the cylynder at less than 1000 rpm? When the oil came out, it was brown like it was mixed with water. Could water get into it other ways than air intake.
I'm not a car expert or any kind of forum regular. I just figured some BMW enthusiasts would have heard of something like this or at least just be interested in such a rare case.
Oil and water (coolant) can make a brown substance like cake frosting, or a milkshake. Really weird problem, blowing up engines. Never heard of this before. Hardly anyone on this forum has chewed up their original engine, much less five!
I do my own servicing. Might want to consider joining Bay Area Checkbook. They do periodic surveys and ratings of auto repair shops, including BMW specialists.
I got money on your brake booster being full of water.
Look it up, it's very common... especially if you park outside or drive in the rain. Are you cabin filter drains clogged, or have they ever been? That'll cause the booster to suck up massive amounts of water. You can test it by pumping the brake pedal and having someone listen for moving water in the booster.
Be happy you're not in the north somewhere, because the water DOES freeze, causing the brakes to be almost useless.
Now THAT makes a lot of sense. I had a slightly squishy feeling in my brakes at one point, like ther was air or water in the line or something but it went away quickly after pressing the brake pedal. Never would have thought they were related. Not something I'd try and do myself though.
Thank you
In all my years of existence, with all the cars I've owned or known, I've never known a person with a street car to go through more than two engines. That is just throwing good money after bad. By engine 3 I would have just moved to another car or maybe had a professional look into it. Posting a question on this board is simply idiotic. This isn't Click and Clack.
Awesome inpute! I only payed for the first motor. The rest the shop covered and did before I even knew about it. Seeing as I'm in the military and gone quite often.
But hey, at least someone was helpful
i knew a guy that had water get into his engine (Honda) and then the next motot had the same problem ,turns out the intake manifold(water cooled on the honda) was reused on the new motor and it was leaking water . so this may be the cause in your motor .is there any part being reused on these motors from the original?
1. Search the forum for any threads/posts on "failed v8 engines" I've heard of many overheated/warped/cracked head & gaskets, but 0 through the block failures.
2. Any attempt of correspondance with BMWNA in regard to a 10+ year old car is a complete waste of time - they don't care.
3. I would humbly suggest finding a different car - like a Toyota Corolla.
The brake booster has my vote. By the way... those big things under the hood are engines not motors. Motors are electrically run while good old internal combustion run our engines. LOL
Well thanks guys, I'll let you know how that turns out. Theres a BMW specialist down the street from me, I'll tow it over there and point them in the direction of the brake booster. This'll be my last effort on this car. I have such hope in it because for being such an old car, it's still great. The wife just got a Sonata Hybrid a couple days ago. If this doesn't work I might be headed that way as well
There truly is a benefit to using a dedicated Bimmer indie. People may scoff at how much I pay for labor, but my shop gets a Christmas card from me every year.
3D is probably the best shop I have ever done business with.
OK HOLY ****! There's a ton of water in my brakes. I really wanna try and mess with this my self. Dont know if I should. I read a few thing about syphoning water out of the break booster. Kinda wanna try that to see if that seems to be the problem then replace it after, given it works out.
Thanks quick99si! I found that in that well under the driver side cabin filter, the brake booster was half submerged in water. Dont think I'll have to take her in just yet. After a lot of trick vacum work and checking a lot of hoses things seem to be good. After I got the water out of that area surrounding the booster it stopped making any water type noises when pressing the pedal. I never actaully got even a drop of water out of the booster it self but there was a little in the vacum hosing between there and the ICV. At this point it's running great and the brakes feel great. Think I'll just take it in to get a general service. I'm at at 132k on the odometer and have no idea what on this 6th engine.
Glad you found the problem, but I still suggest totally draining the booster and then thoroughly cleaning the nearby water drains. It has ruined your engine before, and it will happen again if you don't do something about it. Good luck!
Wow, good call Quick99si!! That was so good that you helped somebody fix a problem as big as that!! Thats what these forums are for! I am glad to see them finally work every now and then. lol
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
