One morning i heard a clicking noise under the hood but it went away after a couple minutes. Later that day on my way from work it did the same thing, this time when i got home it was louder When i turned the car off i try'd to crank it again and it only got weaker and weaker, and then it died. I also smelled a burning smell under the hood when it died. Now when i try to start i can only hear a clicking noise under the hood.:tsk: Could the motor be locked or the starter? No codes popped up or warnings?!
Pop off the main belt and make sure you can still spin all the pulleys by hand. A few of us have had our alternators seize up (mine has) or come close. Regardless, you'll likely find something acting a little funny, and if not, try to start it with no belts on. If it starts while being jumped, but not without, then you have a dying battery. If if does not start while being jumped with the belt off, then you have a bad starter (fairly unlikely). If it starts just fine without the belt on and without being jumped, then it's being dragged down by something that the belt wraps around. Hope this helps!
Can that even happen in that case, the alternator and starter go out at once?
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
