Went out to our e90 with the Peake and saw this code "FC 2E81 Electric coolant pump, speed deviation, speed outside the tolerance". If I am reading that right, it is time to replace the coolant pump. The good news is that it is fairly easy to access, the bad news is that the pump is at least $458 and the thermostat is $120 not to mention the replace bolts, gaskets etc.
Has anyone replaced the coolant pump, is there anything I need to know about before I dive in?
