BMW 750Li 4.8 Liter Valve Cover Leaks Gasket Seal Replacement.
Please Note: I Replace right Side Left Side New Valve Covers.
Please Note: I Replace All 8 Spark Plug Tubes With New Spark Plug Tubes
Please Note: I Replace 4 Cam Sensors 2 On Each Valve Cover" With New Seals"
Depending on Miles May Be Good Time to Install New Spark Plugs And Coil Packs.... This one had 92,000 miles So 8 New Plugs.
NOTE NOTE NOTE - Warped Valve Covers - Major Cause Of Leak :
http://www.fcpeuro.com/ - Purchase Valve Covers From fcpeuro.com
Note: Remove The center engine cover and Looking at your Plastic valve covers pop off the right and left side Valve cover facial covers, now on the drivers side Valve cover left side rear move your fingers slowly where the valve cover sits on the head***8230;....Can you feel the gasket ..?? The Gasket is a Rubber seal TAKE NOTE: These plastic Valve Covers Warp***8230;....there are 4 spark plugs tubes between the covers and the heads and the covers sitting on these tubes help cause the Warping ..
Take Note: Looking at the valve covers Bolts"..2 center by vanos piston and the 2 bolts with half moon notch on the heads These Bolts have to return back to where they removed from because the stops on them are different sizes to keep from cracking valve cover and insure the lower side of the valve covers will seal tight against the heads.
Caution ***8211; tighten valve covers bolts in Multiple steps torque sequence
Up on replacement with new valve cover I set the new valve cover on head then from the top center of valve cover installed the new bolts and Lock seals just getting them started then the long front bolts then the 1 rear bolt that hides back at the cam sensors.
Now take one of the old top bolts with the half moon and get the bolt started center of lower side of the cover***8230;....began to tighten the bolts Keeping in mind the Spark Plug tubes are holding the valve cover up and will set and seal as you tighten bolts in sequence starting from the center then out toward the ends.. Began to install new lower Valve cover bolts, when the valve cover spark plug tubes are seats into valve cover enough to allow lower bolts to reach and grab the studs threading***8230;....Remember to Remove and replace the old half moon bolt you install on lower side of valve cover we use for valve cover with spark plug tube seating ..replace with new bolt and seal with shorter stop shank.
Take Note": This is not a fun job to do so I would Purchase new Valve Covers and New Spark Plug Tubes and when installation I used see through coat of lithium grease on the seals of the spark plug tubes and made sure there sitting completely in the head on reassembly. Also wiggle each spark plug tube when setting the new valve covers back on head to insure the tubes are aligning with new valve covers..
Disconnect Battery neg. terminal
Remove the Engine covers
Remove the Cabin Air Filters Covers
There is a metal Flex Lock on top of the inlet ducks use crow foot and release ducks from firewall.
Remove the rear center cross over 2 - 10 mm bolts left and right side
Remove the plastic locking seat 1 ***8211; 10 mm bolt from right passenger side Cabin air filter lock tab ***8230;....this is sitting over main wire harness box.
Remove the main wire harness box cover
Pull up on the main wire harness allowing you to move the wires to firewall
Remove the 2 torex bolts from center engine cover mounts, this will allow more travel for main wire harness to firewall use a bungee cord to hold out of way of valve cover ..
Remove the 2 cam sensor Male torxe screws and wiggle sensors our of cover
Remove 2 Screws holding plate on eccentric sensor remove the plate.
Stop--------------------------------Vanos Piston Removal-------------------
Mark the vanos piston and mount with marker or paint for reassembly 2 half's
Loosen 4 Allen bolts slowly there is pressure on piston
Hold down on piston when removing last Allen bolt then slowly lift then it will click releasing tension
There is a seal ring for Piston to mount seating I apply lithium grease reassembly
Remove the 4 toreax screws from Vanos piston mount and lift mount off valve cover up out of seal.
Remove the right / left engine air filters and 2 screws from the Ducking now remove Ducking.
Remove 2 Screws from the Antifreeze overfill bottle lift up to release from wheel well
Remove the large Vacuum line off Air pump right front of head going to Power Brake Booster Diaphragm .
Got to Left side back at power brake booster there is a cover 2 torex screws holding this cover keeping this vacuum line in channel support Remove.
Unlock this Vacuum line from power steering reservoir bottle and remove this vacuum line from car
Remove the Vacuum line from the Throttle body that travel to secondary air up over the power steering reservoir ..
Remove the 2 ***8211; 10 mm bolts holding the power steering Reservoir freeing the Bottle from mount.
Right side passenger unplug the coil packs and using flat edge unlock the harness and move harness over the engine
Loosen the ABS Pump
Remove 4 coil packs from cover there tight so take your time may need to move Abs Pump
Now Take your time***8230;.....The essentric Sensor stick up out of Valve cover back at cam sensors.
Remove the Valve cover bolts Keep in mind you have the 10 mm bolt that is back at the cam sensor
All bolts Removed wiggle and lift and wiggle valve covers up off spark plug tubes
-------------------Stop-------------------------------------------------
These Valve covers have to come up over the Esentric Sensor in rear of valve cover first and when reassembly has to go over first***8230;....***8230;....
-----------------------------------------------------Take your time ---------
Remember of reassembly wipe the oil from spark plugs tube seats because this will cause misfire of engine ***8230;....
U can use light see through lithium grease on new spark plug tube seal for reassembly
The Left valve cover is the same TAKE NOTE:----------
On Removal of left valve cover there is 2 coolant hoses heater that will need to pushed under valve cover once free from spark plug tubes or you will have to disconnect the upper hose***8230;....but makes mess with coolant.
Remember the cover lifts up over the Rear Esentric Sensor mount first and goes back over first on Reassembly.
That is about it***8230;....Just take your time, force the valve cover off spark plug tubes, keep in mind of the 1 ***8211; 10 mm bolt back at cam sensors
My New Valve Covers Arrived With New Seal And Bolts.
