Manufacturer: BMW OF NORTH AMERICA, LLC Mfr's Report Date: AUG 25, 2011 NHTSA CAMPAIGN ID Number: 11V438000 Component: EXTERIOR LIGHTING:TURN SIGNAL Potential Number of Units Affected: 241,000
Summary:
BMW IS RECALLING CERTAIN MODEL YEAR 2002-2005 325I, 325XI, 330I, AND 330XI VEHICLES MANUFACTURED FROM SEPTEMBER 1, 2001, THROUGH MARCH 1, 2005. OVER TIME, RESISTANCE IN THE ELECTRICAL CONTACTS MAY CAUSE ONE OR MORE REAR LAMP FUNCTIONS (TAIL LIGHT, BRAKE LIGHT, AND/OR TURN-SIGNAL), WITHIN THE VEHICLE'S BODY PANEL, TO STOP WORKING.
Consequence:
INTERMITTENT LIGHT OPERATION REDUCES THE ABILITY TO WARN OTHER MOTORISTS OF THE DRIVER'S INTENTIONS. THIS COULD CAUSE A VEHICLE CRASH WITHOUT WARNING.
Remedy:
BMW WILL NOTIFY OWNERS, AND DEALERS WILL REPAIR THE VEHICLES FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING OCTOBER 2011. OWNERS MAY CONTACT BMW CUSTOMER RELATIONS AND SERVICES AT 1-800-525-7417.
Speaking of not getting your hopes up, I just called BMW NA, and they said there are no open recalls for my VIN. Thing is, I've already had this problem and had to repair/replace one light. She said to try back in a week or so, and I told her I would, and escallate at that time if there is still nothing. MFers, pulled this shiz with the DISA valve issue, too. Starting to wonder if my VIN is incorrect in their system!
RSPDiver, as Tim's post said, THE SAFETY RECALL IS EXPECTED TO BEGIN DURING OCTOBER 2011.
So when a dealer punches in the last 7 characters of your VIN there's currently no recall flag popping up on his screen. And hence he thinks there's no open recall for your car. Wait until Mid October.
what did you actually do though compared to what BMW is supposed to do? problem is caused by too high of resistance on the connectors. My adapter plug was fried so I just replaced the adapter plug, but that doesn't resolve the resistance problem.
Rather a large year range..Would not be surprised that although a very large number of units have been repaired due to complaints at vehicle owner cost, it still required someone getting sued to bring the current action.
The problem is caused by he use of too small a ground wire in the lighting fixture. OVer time, the wire fails to carry the current and you get a light burned out warning.
By tapping into the existing ground with a second wire (i used a larger gauge) and attaching it to the spare ground terminal on the "plate" of the light fixture, you eliminate the problem.
It takes a few inches of wire, a couple 1/4" connectors and in my case some electrical tabs that are designed to join a new wire to an existing one.
If you search here for "tail light problem" (or something like that) you will find a DIY with pictures.
There is more to this recall than meets the eye. NHTSA's Office of Defects Investigation (ODI) began an investigation of the tail light issue in April of 2009. They elevated the investigation on 8/7/09 and again on 12/18/09. This is an indication to any manufacturer that the agency is not so subtly pushing for a "voluntary" recall. Nevertheless, BMW stubbornly refused. The correspondence between BMW and NHTSA is available for all to see; Google: NHTSA Defect Investigations. The final ODI investigation was EA09019.
In all my years of following NHTSA investigations and recalls, I have seldom seen a manufacturer fight so hard to resist the agency's desire to conduct a recall. One of the documents posted shows that there was a July, 2011 meeting with NHTSA and BMW representatives; no doubt heavy arm twisting on the part of NHTSA.
For those who had the tail light repaired at the dealer, the repair may have been very expensive if out of warranty. Under recall rules (statute), some repairs made prior to a recall may be covered for a certain time period, I'm not sure about DIY.
I had posted in this forum a long time ago for members to keep their receipts.
Unless there are any unusual aspects to this recall, I believe this will apply:
Note: The NHTSA/ODI Engineering Analysis was opened 12/18/2009.
If I Had a Defect Repaired at My Own Expense Before a Manufacturer's Recall, Am I Legally Entitled to Reimbursement from the Manufacturer?
Yes, under certain conditions. Manufacturers are required to provide reimbursement for certain owner's costs to remedy defect conditions prior to a recall. Manufacturers are required to reimburse owners for costs incurred to remedy a defect based on a start date of either NHTSA's opening date of an Engineering Analysis or one year prior to the manufacturer's notification of a defect to NHTSA, whichever is earlier. The closing date of eligibility for reimbursement of repair of a motor vehicle is 10 days after the manufacturer mails the last of the owner notices informing owners of a cost-free safety defect recall. For replacement equipment, the closing date is either the same as for motor vehicles or 30 days after the manufacturer's closing of its efforts to provide public notice of the existence of a defect, whichever is later. Documentation of the requested costs is required.
While this is a new requirement, manufacturers have in the past often voluntarily agreed to absorb such costs, and have provided refunds to consumers who had defects corrected prior to a recall, providing that consumers have been able to present documentation to prove that the earlier repairs remedied the defect in question.
Super. Nice of BMW to finally, Finally, FINALLY acknowledge the problem. My dealer SA said "what problem? You must have damaged your car, have you been in a crash recently?" which of course promptly ended my very-short relationship with that SA *and* his dealership employer.
Of course, I fixed it myself: first by doing the "official" DIY in our wiki on one side, and then realizing I could do it much, much easier with my boat electrical repair kit. I've had no dim, or non-existant, taillight bulbs since then. It's all about providing a proper, hearty ground connection to the taillamp assemblies.
The DIY was simple for those so inclined (brown wire splice), but MANY payed $200 per side to have this fixed. BMW reported more than 30,000 dealership repairs...I estimate that it cost owners more than $6,000,000 in repair costs while BMW NA fought NHTSA tooth and nail for years to have this obvious defect become a recall as NHTSA sought. I'm very disappointed in BMW's attitude.
Who hasn't had this problem? The year range for this recall is actually too narrow. All the E9X's have the same problem. I have had all the tail light sockets and bulbs changed twice on my 07 328xi coupe!
For some odd reason, I`ve never heard of this problem affecting coupes....any feedback or opinions on that angle ?
And as far as BMWNA`s attitude goes, well, let`s just say the new corporate motto should be "We`re Only In It For The Money" . Things have certainly changed since I bought my first Bimmer in 1980....back then, there was not much plastic on those cars, the owner`s manual was quite informative, like a mini-Bentley manual, (they actually expected and encouraged you to work on your own car....what a concept ! , and the toolkit was about twice the size of the current one.
I have had issues with all of my taillights/blinkers for years. I own a 2001 325i. What about my fix? As a matter of fact, I just spent money on my left taillight and right front blinker! The fact is, most of those are probably past their second owners who probably don't give a rat's *%# about this recall.
Bummer for all those outside of the recall range. This is specifically aimed at issues related to the open ground connection and over-heating/melting of the 8-pin connector in the tail light assy. of the targeted E46s.
WOW. Why did it takes this long for this recall?:tsk:
BMW has known about this issue for years and issued a TSB. 3 years ago I took my car to the dealer for this issue and was told it would be $400 for the repairs. I told my SA that I was aware of the TSB (which covered in-warranty cars) and would like BMW good will assist. The tailights were repaired free of charge. Wonder how many people ended up paying for the repairs?
It's worth noting the italicized and underlined paragraph on the last page of the DCSNet e-mail, which says those who had repairs performed before December 18, 2009, aren't entitled to reimbursement.
Yes, under the rules (statute) established for recalls, when the NHTSA Office of Defects Investigation (ODI) opens an "Engineering Analysis" investigation against a company as NHTSA did on 12/18/2009, that's the "go to" date for recall reimbursement. BMW would have know that, but nevertheless kept resisting NHTSA's "desire" that a "voluntary" recall be conducted. In all my years of analyzing NHTSA recall events, I have seldom seen such stubbornness on the part of a corporation.
Looks like in you photo of the melted wire you may want to clean the primer overspray off the connector. that is certainly not making good contact on the lower wire . I think they could do the old "been in a wreck" refusal on that one.
Mid-October can't come soon enough for me. I'm tired of seeing the stupid car graphic with my "right tail light out" warning. I pulled the boot off the wiring assy once to look and see if there was anything obvious but didn't see anything then.
I think I subscribed to the earlier post of this investigation pending. Now I'm stoked that it's an official recall.
Sure a lot of posts over an issue that costs $5 and 20 minutes to fix with the DIY on this site. Personally, I'd feel better doing it mysefl than leaving my car with BMW for a couple hours so they can put back in what was faulty in the first place.
All I can say is...if BMWNA will dig in their heals this way over a $5 fix item, it does not bode well for numerous, larger failures of their cars.
Me too, if 20 minutes actually meant 20 minutes. All my projects take at least double the time quoted. I'm not incapable, its just that I forget to factor in the time it takes me to do it wrong the first time, then break something in the process of doing it the second time thus requiring me to fix that which all amounts to a 2 hour job for me.
Add that to the fact that I have about 10 other jobs that are supposed to take anywhere from 10 minutes to 1/2 day (read 4 hours and 3 weeks respectively). I'll take it to the dealer...
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
