Fan clutch kaput?
1K views 9 replies 5 participants last post by  cn90
#1 ·
With the engine running at operating temperature, I can stop the fan with 1 finger and spin it backwards would you say that the fan clutch isn't working? :eeps:
#2 ·
Nope. It only engages when the car is struggling to maintain operating temperature.
Go drive hard for a bit and pop the hood, try stoping the fan immediately, after one minute, and 3 minutes. Should engage at least at one of those points. But, use a thin newspaper roll, not your finger. :eek:
#8 ·
Coolant temp was 3\4 to red and getting hotter and i could still stop the fan and spin it backwards with the engine running.
:confused:
Those are very different things.
Yes, the fan clutch is bad. As in my first post, it should only engage if the engine is struggling to maintain op temp. If you were idling at op temp it shouldn't be on in winter in most cases. If the temp was at 3/4, hell yeah it should be engaged.
3/4+ is NOT op temp.
#10 ·
I have a simpler way of doing this.
With engine hot, place your hand behind the fan, if it blows well (like your living room standing fan at home @ medium speed), then it is fine.
Or hold a piece of paper behind the fan (between the fan and engine), if the paper flaps, then fan is good.
Sorry not to be scientific!
