Mileage: ~103,000
Over the past few months the "low coolant" light has turned on, which never happened before. I'd top it off and after a month it would turn back on. Off I went hunting down the leak... Found it!
It appears it may be leaking from:
This one was taken from the side.
Based on the last picture, this hose goes from the water pipe connector all the way to the thermostat. Should I replacing this hose? Is this the overflow hose?
The diagram from RealOEM.com says the part # is 17123422785. When I plug this into certain sites it says its not compatible with my vehicle...
Parts Ordered:
www.ECSTuning.com
Coolant Expansion Tank
Mfg Part# 17117573781
ECS Part# ES#2091434
Water Pipe Connector
Mfg Part# 17112248409
ECS Part# ES#38012
www.Bavauto.com
Expansion Tank Thermostat
Part # 17 11 1 437362A
Upper Radiator Hose
Part # CHR0186P
Lower Radiator Hose
Part #CHR0187P
Expansion Tank Retaining Clip
Part # 17 13 2 248 252
Fluid Level Sensor
Part # 52041
Didn't order any coolant since I already have some.
- Area where the expansion tank sits on the mounting plate
- Water pipe connector.
- Level sensor
- Overflow hose?
Parts Ordered:
www.ECSTuning.com
ECS Part# ES#38012
www.Bavauto.com
Upper Radiator Hose
Part # CHR0186P
Lower Radiator Hose
Part #CHR0187P
Fluid Level Sensor
Part # 52041
