All German Auto has developed a custom solution for repairing a 60+ hour, $10,000 coolant leak problem on BMW 745 N62 V8 motors for less than $2,000 completed.
Symptom: Coolant Leak
Coolant will be leaking from hole in front of timing cover (located close to water pump towards passenger side). In front timing cover the hole is approximately a quarter inch.
Problem:
Rubber seal on aluminum cooling tube has failed. Coolant is leaking into back area of engine timing cover and out of hole.
Bigger Problem:
Replacing this seal/tube is a very, very big job and very expensive.
Solution:
Install an AGA collapsible cooling tube. We have designed a tube and seals that can be installed (by experienced tech) in under 10 hours.
Benefit:
A potential $7,000 ***8211; $9,000 repair job is now achieved for less than $2,000. Additionally, the repair can be completed same-day compared to 2-3 weeks.
Expanding Cooling Pipe for 745I & IL model year 2001- 9/2003 N62 Engine
Video -
AllGermanAuto's YouTube Channel -
http://www.youtube.com/AllGermanAuto#p/a/u/0/UoCED1jyfL4
Get more information about the All German Auto Expanding Cooling Pipe on their website here - http://www.agatools.com/part/bmw-n62-coolant-pipe
Or view the full details in PDF format here - http://www.agatools.com/files/index/download/id/1425926536/
Problem:
Bigger Problem:
Solution:
Benefit:
Video -
