I had NO experience with BMW when I bought mine 2 years ago. As of today, I have replaced literally everything on my car except the motor (and I am NOT kidding!). They are well laid out and very easy to work on. You will need a good metric set of tools and a set of torx sockets and allen sockets. Other than that, it is a car and pretty simple. Example: The brakes on my BMW use the EXACT same size sockets and allen heads as my 2001 Jeep Grand Cherokee, who'd a thunk it?
I found my E46 harder to work on than my last few honda cars. I also found multiple things would wear out much faster than other cars. For example, when's the last time you've changed CABs or Final Stage Fan Resistor on another make. The drive made it worth it though.
Generally, it's not too difficult with a basic set of metric tools and such. The problem usually lies (for me, at least) with the electronics and sensors. They can be finicky and sometimes unpredictable.
You can literally find a lot of good DIY on this forum. So if you study the DIY + pictures, you should be able to try it. I guess you have to have the space and guts to take that first steps. I'm still learning but reading these DIY does inspire you to do some of the work yourself. But you have to be comfortable and know the risks
my opinion is that it depends on what you are used to working on. For example, when compared to my '01 Dodge Stratus R/T coupe, the front engine rear drive layout is naturally easier (don't have to take everything including the intake manifold off just to change spark plugs). 'course the bimmer is nowhere near as simple as the '74 dodge dart and '67 Imperial big block that I restored, lol. My only complaint is the reliance of BMW on overpriced "special tools" to drive the customer back to the dealership for service...unfortunately this seems to be becoming an industry standard. Other than that it's very well engineered for repairs, even if more "complicated"(ie. Oil seperators) this site has just about any DIY repair available. In summary, the how to's are there, so long as you have the testicular fortitude to give it a shot. Hope this helps.
I hate to resurrect a dead thread but I think people need to know a few things about owning a BMW. I have worked on so many types of cars from a 4g63 AWD turbo car to a Fiat 600D. From the most complex to the simplest. My experience level is high so I think I have a pretty good room to talk on the matter.
1. BMWs were designed by German who truly love to make things easy. A GREAT example of how easy these cars are to work on is, what should be, a very labour intensive task: The water pump. On my E46, it took less than an hour to change out, involved all of 4 nuts, and required absolutely NO silicone sealer. There were no parts that had to come off (unless you have an auto, then you have to remove the radiator fan, but still easy), no gaskets required, and bleeding out the system was also ridiculously easy.
2. Brakes require all of 2 7mm allen screws per wheel. Spark plugs require all of ONE special tool that is in the tool shelf of the trunk, and the fuel filter is 4 bolts that are easily reachable when the driver's side of the car is jacked up. Oil changes are easier on a BMW than any other car I have worked on (mostly because the filter is accessible from the canister under the hood.
In short, if you love working on cars, you will love your BMW even more because everything seems to be DESIGNED to be worked on, UNLIKE so many other cars. Parts are usually the same, if not cheaper, than most other cars. Just don't think that because it is a 'luxury car' that parts are more expensive. In Germany, these cars are NORMAL, non luxury cars. I love my bimmers (and this is coming from a dye in the wool American car freak).
Before owning 330ci I had (and still have, actually) Toyota Camry with V6 engine (1MZ-FE, 1996). In comparison with the V6, the BMW's I6 is so easier to work on! On that V6 even replacement of spark plugs is problematic due to the engine is turned by 90 degrees and one of the bank is facing toward the firewall, and to replace plugs there it is necessary to remove manifold with throttle body!
You want fun? get a '76 Jag XJ12. Had a water pump go on me but to get it off,you had to take out 3 bolts. Simple enough, except these bolts were 6" long so the rad was in the way to get them out completely. To take the rad out, you had to remove the grill but that won't come off unless you took the front bumper off. Get the picture? Bimmers are a dream to work on.
By the way, it turned out it wasn't even the water pump that was bad.
I worked on one of those Way Back When....did a brake job on it. The rear brakes were inboard-mounted, close to the diff....great from a performance standpoint (it reduces the unsprung weight at the wheels, allowing the rear suspension to react faster), but totally blows for the poor guy who has to work on it. E46s are a dream by comparison....
A GREAT example of just HOW much the happy Germans want you to work on your BMW is the fact that the core support is very easily removable. Like you guys said, taking off all the other parts just to get to something simple is the way of cars these days. I remember doing a water pump change on a 3.8 Mustang, and GOOD LORD was that a lot of deconstruction to replace it.
coming from the domestic market, I'm finding that BMWs are easier to work on. A little more expensive because the parts are in my experience higher quality, and the systems more advanced. What this means in the long run though is that you can have a car last you well past 200,000 miles. Mine's at 188xxx and doing just fine.
These cars have a few stupid things here and there, but overall, they are very nice to work on. If you think these cars are difficult, try to replace a window regulator in a volkswagen passat.
It's a luxury car? You sure about that? I wouldn't call it a luxury car. I'd call it a performance sedan perhaps, but not a luxury car. The materials used are too chintzy to qualify as such, IMHO.
This is my first car and I have never worked on cars before this. I find it easy compared to my friends 2001 Nissan Maxima Everything seems to be neater and easier to get to and so forth.
Can't go wrong here. E39 forum will be your main place, but a lot of similar stuff of e46s so that can be a good place to lurk. Note the links near the top of each forum's page that say "view the Exx wiki." Lots of good info. E39 and e46 probably have the best ones on bimmerfest.
Mechanically quite easy i think, but when ever something is wrong with electric devices then it can be more tricky. Anyway this forum and these mates can help about any problem you might have with e46.
Its easy to work on.. All you need is a pair of balls and say i can do it.. And if you cant find the problem and need a guide... Bimmerfest that sh1t.
:thumbup:
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
