Saturday afternoon, my F10 with 2500 miles on it gave me a warning that I was low on oil. It said I needed to add a quart. Since my dealer was closed until Monday, I planned on calling them today, but now the warning is gone. In the graph that they show you, I'm showing about a quarter of the way up from the "min" line. So it's now saying I'm a little low but still ok.
I will call my dealer about this, but I'd also like to get a second opinion from you good folks on Bimmerfest. So,
* Isn't it "wrong" that a new car could be low on oil already? Could this be indicative of something more serious than just a need to add a quart?
* Why would the warning come up, and now it's gone. Perhaps because it was colder outside on Saturday...?
You will find that alot of people with the N63 motor have reported it burning a good bit of oil. I averaged about a qt every 2,000 miles up until I switched to Mobil 1 0w-40(still an approved BMW oil) at 10,000 miles and now it's going through a qt every 4-5k. When I asked the dealer they said the tolerance is a qt every 700 miles which is insane but whatever. Actually in my last discussion with a BMW tech he said it wasnt the motor itself that burned oil but rather the turbos that had loose tolerances which increased their life. I call bull**** as other NA BMW motors burn oil too but that's what I was told. I'm sure your fine just monitor it closely you probably were in a bad position the last time you checked it.
No worries :thumbup: The 550 motor is an oil burner and your quart low at 2500 is about average from what I've read. Mine needed the first quart at around 3000, it has now gone over 5000 since the last oil change and it is only 1/4 of a quart down. Also, do not believe the oil sensor 100% because it fluctuates up and down about 1/4 quart.
Make sure your car is level too. My driveway is steep, and if I turn on the car and sit in it waiting for my wife to come out, I will get a misread on the oil level. So, I don't turn it on until I start driving.
Oil level message came on and visited the dealer and they added a quart of oil in the service lane while my wife used the restroom and I was on my way. 7555 miles and average 20 mpg. I will say my first BMW and before that had three MB and never had to add oil to a car.
Block is not magnesium it is a hypereutectic aluminum silicon alloy and should not be the cause for the oil burning. If your engine is leaking take it to the dealer as my engine burned alot at the beginning and still burns a good bit yet has ZERO leaks.
Buddy I fix the n51 and n52 engines all day long and i tried welding the a block in one case and nothing welded only magnesium rods thus magnesium block don't believe me try it for fun ill supply the welding rods I have a spare block to prove it
Buddy thats great however in this thread we are talking about the N63 which is not a magnesium block like the N52 is. Even the N54 and N55 aren't magnesium as bmw decided not to use their magnesium block design on turbo motors.
Btw the dealer ain't got **** on me I fix all there **** ups when people don't wanna by a new engine maybe cuz the msrp is $10,488.00 they send them to me one of the few shops in southern California that can actually repair that engine
Now that I know what the block is made of and were not to take it for welding... Mine was a quart low at around 3500, I was not near a steeler so just put a quart in. I did a oil change at 5K, at 10K oil is still full, so I may not be burning as much now that the engine has broken in some.
looking at your pass posts, it seems like you never follow BMW's recommanded break in procedure. I hope thats not the cause of your engine consuming oil. If you are leasing, then its all good.
Mine needed a quart every 3000 miles until it went in for an oil change at 12000 miles. I am at 17000 miles now and the gauge still says its full. Maybe people with new cars should pay for an oil change at 3000-5000 miles and the engine will no consume oil as fast?
I'm at 2900 with max showing on the oil display. i've had the car 6 months and followed break in, but have not driven it like a granny. it's opened up quite often. exhaust shows no soot....as i know this isn't a VANOS nor DFI engine. my porsche used oil, and my 535 dirtied it's exhaust within seconds of scouring it clean.
i bought 1qt of 5W-30 Castrol Edge Synthetic as my back-up. Per the manual, I was surprised to see that the N63 ran 5W-30.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.2K members
Since 2001
