The all new 3 series coupe, which is being re-branded as a 4 series coupe will debut as a model year 2014 in the summer of 2013. BMW has been busy testing the base model 428i coupe rumored to have the same turbo 4 cylinder N20 that is available in the current 2012 and 2013 328i. The big engine 4 series coupe will have the turbo 6 cylinder N55 found in the 21012 and 2013 335i sedan but the power will be bumped to the 320hp range.
The 4 series test mule spied here is the N55 powered 440i coupe with a power bump to 320hp. The power bump is part of BMW's strategy to move the coupe up market from the 3 series sedan creating a distinction between the sedan and coupe markets as they have done with the 5 and 6 series. The 4 series coupe will come with more standard features and a higher base price furthering the gap between the 3 series sedan and 4 series coupe.
Much of the 4 series coupe design is still under wraps as we're just under a year out. While this cars headlights are clearly test car units the final F32 coupe will have a headlight design that mimics the F30 3 series sedan, wrapping all the way from the fender to the kidney grills. The grills will be much wider then the 3 series sedan with a look similar to the 6 series coupe. At the rear the trunk lid has been styled to wrap into the rear window. The big engine 440i retains the split, left and right single exhaust were the 428i will have a left side dual exhaust.
As we get closer to the press launch of the 4 series coupe the camouflage will start to drop off the 4 series so stay tuned for more and more revealing spy shots of the 2014 4 series coupe. Based on the size and general lines you can see so far, do you think the 4 series coupe is going to be HOT or NOT?
