2001 BMW 325i Major Issues...
About 2 weeks ago my car was slow to start. Then I tried to crank it after running into a store for 5 minutes or so and it wouldn't start at all, just a clicking noise. All of the peripherals like the radio, lights, etc. were working fine. Once I got jumped off I went straight to Autozone and they performed a charging system and battery check. The charging system checked okay (so the guy said), and the battery had about 515 cranking amps. I replaced the battery at his recommendation with a Duralast 49L. 2 weeks later and I had no problems until yesterday I'm on the way home and the battery light comes on a few times. When I got to the house I cut it off and immediately tried to power it back on and again just the ticking noise. It was late so I let it rest for the night. Turned it on the next day and it turned on fine. I let it idle a while and cut it off and tried to crank it back up and it wouldn't crank. I took a look and it seemed like the wires to the battery were loose so I tightened them up, jumped it off and drove around the block about 4 miles or so. The battery light came on intermittently and also the brake, dsc, and anti-lock brake lights came on intermittently too. When I got it home I just let it idle for about 2 or 3 minutes and without warning and without the temperature gauge going up it overheated spewing anti-freeze everywhere. Tried to pour more antifreeze into it and the reservoir seems to be broken.
The only thing I could thing is there wasn't enough power to cut the fan on? I had it serviced under 3000 miles ago at the dealer. It was frickin 2000 bucks and I don't have any cash to fix it right now so it definitely stays parked for at least 3 weeks. What could the root problem be?
What service was two grand?!
Any aftermarket stereo equipment?
Sounds like a charging system problem
Sounds like a charging system problem. The alternator/battey light should NEVER be on when the car is running. Your battery is going dead because it is not being charged. Your car is running on low voltage, with all the computers contain within, strange things WILL happen. This will include the possibility of the radator fan not running when needed.
There are probably multiple problems but likely the battery is not one of them. |
re: causing hell
I have a 2001 330I and it has the same symptoms as you had with your charging system. The charging system will not charge the battery and the battery light flashed on and off a few times and I too just put in a diiferant Ipod BMW cd player.
What was the problem with your car? Thank You, Roger PS. The battery light does not come on when the key is in the on postion. |
In regards to your engine light after your alternator change, there is a good chance the shop did not properly hook up the vacuum system that the alternator is plugged into...
I don't know a lot about these issues, but my battery light was coming on intermittently (the red one, which the book says means stop now). The car was running fine.
Turned out there was a TSB (they didn't give me the number). and replacing the voltage regulator solved the problem. |
E46 alternators are weak - I went through two of them in my M3.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed 2002 BMW M3 Alpinweiß/Black 1999 323i KP/GTS2 Alpinweiß 1990 325is Brilliantrot/Tan 1989 325is S50B30US Alpinweiß/Black 1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
stupid question
Will leaving the battery hooked up while putting in a alterantor fry the voltage regulator
Not sure, buy why would you leave the battery hooked up when doing this install anyways? Doesn't seem smart to me...
stupid question
I was in a hurry lol stupid move,i had it tested yesterday
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wall Street Journal Article on BMW's Past, Present and Future | Salvator | General BMW | 65 | 12-25-2010 08:22 PM |
| Option code list | Terry Kennedy | General BMW | 16 | 05-14-2006 03:59 PM |
| The 2006 Bmw 7 Series | tim330i | BMW News Articles and Announcements | 0 | 01-27-2005 02:22 PM |
| X-post: Lemon Law, or keep waiting? | pylt | 3 Series / 4 Series | 18 | 05-09-2004 05:29 PM |
