Old 01-22-2006, 07:48 AM
jjdecesare jjdecesare is offline
Mein Auto: 2003 745 LI
Satellite Radio
I am new to BMW and to this Forum, so be easy on me.
I purchased a 2003 745 LI and would like to add Sirius or XM Satellite raido and can not find an aftermarket interface. Can anyone point me in the right direction?
Old 01-23-2006, 12:09 PM
CITYCOP CITYCOP is offline
Mein Auto: 2002 745I
radio
If you find one let me know I purchased a subscription for my other car but when I purchased my 7 it was not available I have an 02
Old 05-05-2006, 09:03 AM
WarEagle745 WarEagle745 is offline
Mein Auto: 2003 745Li TitanSilv/Blk
I have the same question--most interested in XM. Right now I have the Audiovox plug-n-play unit (has a built-in FM modulator). Though I've found a very inconspicuous place for the antenna (which works well), I hate the unit constantly plugged into my lighter outlet (plus, the auto-on and auto-off feature of the unit will not work with power coming from the lighter outlet). I would like to have it wired, but I admit I'm afraid to turn my baby over to a stereo shop. Suggestions?
2003 745Li (03/03 build, so Sirius not available)
Old 05-17-2006, 11:46 AM
*Reasonable* Solution for XM in '02 and early '03 E65
This is a *reasonable* solution that I'm happy with so far. The installer put the new XM SportsCaster unit (approx. $60) in the bottom drawer of the console. He drilled a hole in the back of the drawer about the size of a nickel and fed the power and antenna wires through it. The drawer is perfectly functional--you can leave the drawer open if you want to be able to change the stations and access the buttons or you can choose a station and close the drawer (leaving the unit completely out of sight!). The unit comes with its own remote control. The unit has built-in FM modulation that works well in my area. See XM's website for details on the unit. [See pictures of installation below.]
For the antenna solution--don't laugh--I purchased a basic stainless steel shower drain (approx. $4) and painted it flat black (approx. $1). (The magnetic antenna needed metal surface for reception.) I affixed some of those rubbery pads, meant to hold things like cell phones and PDAs on the dash of your car, to the bottom of the metal and just laid it in the back window. From the outside of the car, it is barely even visible, because it is black and is sitting on black leather. The installer ran the wire out of sight (I believe in the door facing) to the back of the drawer to connect to the XM unit. [See pictures of installation below.]
Again, I think it's a reasonable solution!
Name:	XM in Drawer.jpg
ID:	75878   Click image for larger version
Old 04-20-2007, 08:55 AM
drockstar's Avatar
drockstar drockstar is offline
Mein Auto: 2002 745Li
Come'on bro....a shower drain? You don't need metal for reception. Just use a small piece of velcro. And hide that wire. The "in-drawer unit" is sweet. Good idea.
I have the Sirius S50 mounted beside the center console. My antenna is on the trunk lid... see the image.
Name:	ANTENNA LOCATION.jpg
Old 04-13-2007, 02:56 PM
civilrock civilrock is offline
I am really amazed that in 3 weeks of searching the internet that this is the best solution I've seen yet for getting xm radio in a 02-03 7 series. I can't believe that there's no good direct connect solution. Anyone?
-kevin
Old 04-19-2007, 11:39 AM
WarEagle745,
I bought the same unit (Sportscaster - because XM Radio has a promotion right now and it's free with 6 months of service). You're right, it fits in the drawer perfectly, and the color of the backlight is the exact same as the colors of the dash.
Anyway, do you know where the antenna is on this car? Included in the packaging is a "sure connect" piece that clips onto the antenna. I'm not really sure where that is. I installed it last night to test it out, and see if it works (I haven't removed any panels or drilled any holes) and I just ran the "sure connect" to the back dash as well and wrapped it around a headrest. As I drove to work today I realized that I either need to find the antenna or figure out a direct connect Aux solution. Right now the sound quality is worse than FM radio. There is another post on this site that I have been reading/posting about taking apart the FM radio box and soldering in an AUX input; you should check that out.
Note: I have the Satellite antenna on the back dash in about the same spot as you, but I seem to be getting good reception (full bars) with out the metal drain mod (great idea btw).
-Kevin
Old 04-19-2007, 12:00 PM
Yes, search before you ask, I know.
this site is awesome:
http://www.realoem.com/bmw/showparts...95&hg=65&fg=30
-Kevin
Similar Threads
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 03:59 PM
Bmw And Sirius Satellite Radio Extend Exclusive Relationship Jon Shafer General BMW Questions 37 01-18-2006 12:56 AM
Satellite radio question. PeteG E90/E91/E92/E93 (2006 - 2013) 12 08-11-2005 09:45 PM
Satellite Radio In Europe smokinlu E46 (1999 - 2006) 10 06-25-2005 02:45 PM
XM and Sirius Satellite Radio??? Upcoming gadgets for your ride BayDetailz General BMW Questions 0 01-24-2002 09:48 AM
