Old 10-06-2002, 06:59 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
HMS Rollbar
About halfway through getting the HMS Rollbar installed.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 10-06-2002, 07:58 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
WOW!
WOW!
2 questions:
1) Will the top still go up over it?
2) If the answer to number 1) is yes, (and I realize this is driver dependent), do you see any problem passing the helmet clearance chech when the broomstick is laid from windshield to rollbar?
facebook.com/sctsracing
02 M3 SMG Coupe - prepared class BMW Club racer
08 135i 6sp - stock class BMW Club racer
Photo gallery
Old 10-07-2002, 05:33 AM
Tommy V Tommy V is offline
Send a message via Yahoo to Tommy V
Mein Auto: 2002 M Coupe
Is it a bolt in? And if it is, what are the negative issues pertaining to risk of injury versus a weld in unit?
Thanks Randy.
Tommy
Tommy V
02 Steel Grey MCoupe
Ground Control Suspension: 450F/600R Eibach - Koni SA
GC Camber Plates -2.3ft//-2.0 rear (from susp drop)
Ground Control Rear Mounts
Supersprint Dual DTM
UUC Short Shift & Tranny Mount
3.46 Differential
SS CL Stut Bar
Carbotech Panther Plus Pads
Goodridge SS Lines
Euro Rotors Front/Castrol SRF
ACS Splitters
Wheel Studs
Blackstone Lab Lead Reports: 3,5, 10 now 13
Old 10-07-2002, 06:56 PM
The Roadstergal's Avatar
The Roadstergal The Roadstergal is offline
Butting back in
Mein Auto: GS500F
Very nice. I think the HMS (and hard dog) rollbars look very sharp on the Z. Let us know how it feels...
"This is a revolution, dammit! We're going to have to offend SOMEbody!"
Old 10-07-2002, 07:09 PM
>>> Yes.
>>>As I sit in the car, my unhelmeted head is about 3" below a straightedge laid across the windshield header and the rollbar.
Is it a bolt in?
>>> Yes.
>>> I'm not certain that I understand your question. Are you concerned the rollbar will come unfastened and strike an occupant?
>>> Thank you! I'll give you my impression after the autocross on 10/20/02. I am most interested in the stiffening benefits of the rollbar, I have no intention of testing its rollover protection
Randy Forbes
Old 10-08-2002, 05:30 AM
My question regards risk in a rollover. Welds are stronger than bolts. What is the risk of shear? Does the rollbar come with an injury disclaimer?
Thanks Randy
Tommy V
3.46 Differential
SS CL Stut Bar
Goodridge SS Lines
ACS Splitters
Wheel Studs
Old 10-08-2002, 05:24 PM
Good luck getting a manufacturer to stand behind components used in racing!
Taken from Simpson catalog: (as an example)
"WARNING/DISCLAIMER
Motorsports are dangerous. No warranty or representation is made as to the products ability to protect the user from any injury or death. The user assumes that risk...."
Check out anybody's catalog, and chances are you'll see the same wording.
If you want a welded in rollcage, you'll have to contact TC Kline (assuming that he has re-established a relation with a suitable fabricator).
Randy Forbes
Old 10-09-2002, 09:11 AM
JoeZ's Avatar
JoeZ JoeZ is offline
Mein Auto: 1996 Z3
Any more pics to show? At first I didn't really like the look of the HMS but now it's growing on me and I'm seriously considering it. I've got an early Z3 without hoops and I think that a retrofit would cost just as much if not more than the HMS, and the HMS would be safer (I'm a little crazy sometimes).
Old 10-09-2002, 07:00 PM
Joe,
I'll get some pictures up in a few days.
I just put the car back together tonight (also had the center console out...must be Stygar/Maddux influence).
I need to get the car cleaned up a bit, then I'll get some finished shots of it.
You'll be buck$ ahead with your swap, I still have to order the NON-rollhoop cover that goes across the rear console area.
If you want any detail-specific pictures, let me know and I will get them for you.
Randy Forbes
Old 10-09-2002, 07:51 PM
JoeZ's Avatar
Mein Auto: 1996 Z3
1 more question-
Is raising the top more difficult with the HMS rollbar? I don't have a power top so I'm used to reaching around for it but does the bar get in the way and give any problems?
Old 10-09-2002, 08:01 PM
I haven't yet got the hang of it, after all, I'm used to stepping on the brake and pushing a button
Depending on the length/strength of your arm, you may still be able to lift it from the driver's seat.
One thing that you may be able to answer for me:
Does the top bounce up & down when in the lowered position?
I used to be able to count on the hydraulic cylinder to keep it tensioned when lowered.
Now I am concerned that it may have a tendency to float when going down a bumpy (95% of Toledo) road.
Randy Forbes
Old 10-09-2002, 08:11 PM
JoeZ's Avatar
Mein Auto: 1996 Z3
My arms aren't that long so it could be a slight problem for me, but I'm sure I'd get around it. As far as bouncing goes I've never noticed any bouncing at all. However I should state that I use the boot more often than not and that would hide the bounce if it was there, but I haven't ever noticed any.
Old 10-10-2002, 03:52 PM
Installation complete
The rollbar is secured and all the debris has been cleaned up.
No driving impressions yet, but I'll probably put a hundred or so miles on it tomorrow.
Season's last autocross is October 20th and I'm hoping to notice a difference!
Only thing left to do is fit a new cover over the sub woofer, doing away with the three individual pieces in favor of one intended for vehicles without factory rollhoops fitted.
It was ordered today from Paul Mclaughlin @ BMW South Motors.
Compare the two:
Randy Forbes
Old 10-10-2002, 03:54 PM
Butting back in
Mein Auto: GS500F
I love it. Be sure to give us commentary after the autoX.
My friends with rollbars - and long enough arms to reach - reach one arm under the bar, pull it up and feed it to the other arm over the top of the bar. It's quite a sight.
Old 10-10-2002, 06:56 PM
JoeZ's Avatar
Mein Auto: 1996 Z3
Looks great!! How about another pic from the rear a little closer up?
Old 10-10-2002, 07:04 PM
On Cue!
I was holding off because I don't have the rear cover for a non rollhoop car yet (but it is ordered).
Randy Forbes
Old 10-10-2002, 07:11 PM
JoeZ's Avatar
Mein Auto: 1996 Z3
I have to admit the HMS bar is really starting to grow on me. I like the aggressive look and you can't knock the increased safety. How long was the install? Can it be done with an everyday set of tools?
Old 10-10-2002, 07:26 PM
If this link works, you can get the complete instructions from their website:
http://www.hmsmotorsport.com/shell.p...tip=roll%20bar
But to answer your question, it could've been done on Saturday...
I just elected to start on Sunday afternoon (I know, crazy).
Simple hand tools should get you through.
Randy Forbes
Old 10-13-2002, 12:54 PM
Christian's Avatar
Christian Christian is offline
Project No Budget 1.9
Send a message via AIM to Christian
Mein Auto: 1997 Z3 1.9
Originally posted by JoeZ
1 more question-
I have a Hard Dog roll bar, but the design is similar to the HMS. It's still possible to raise the top while seated, but it becomes a two handed affair. Not too bad though.
Old 10-13-2002, 02:04 PM
JoeZ's Avatar
Mein Auto: 1996 Z3
Now I'm really wanting a rollbar! However I'm falling quite a bit short as far as the HMS goes. Why does it cost $895 when the hard dog only costs $500? I like the look of the HMS better but it's gonna take me a while.
Old 10-14-2002, 11:48 AM
D///Mill D///Mill is offline
Send a message via AIM to D///Mill
Mein Auto: 2000 Z3 "///M coupe"
Question Padding needed? ...
In drag racing, cars quicker than 12-flat need at least a 6-point roll-cage. Another requirement is that it be padded using the wrap-around foam. Is this NOT a requirement for auto-X? Just curious. TIA
Doug Mill
Bellevue, WA
Old 10-14-2002, 11:52 AM
Butting back in
Mein Auto: GS500F
Depends on who's running the AutoX, but at the WWSCC ones I go to in Seattle, they don't even require a rollbar. The speeds just don't get very high...
Old 10-14-2002, 05:34 PM
Sven Odin Sven Odin is offline
Svenska
Location: Sex should be like driving a Riced out Honda... slow, obscene, and loud enough to wake the neighbors....
Mein Auto: '98 Z3 1.9L DASC
Maybe a stupid question on my part.........For the Z3's equipped with roll hoops, do they have to be removed in order to install the HMS rollbar?
1998 BMW Z3
Downing Atlanta Supercharger
Borla exhaust
My Other Rides:
2002 Chevy Tahoe Z71
1998 Corvette Coupe (mod fever)[IMG]http://www.corvetteforum*****zeroimg/smilies/reddevil.gif[/IMG]
Old 10-14-2002, 05:42 PM
The rollbar is NOT required.
I wanted it primarily to stiffen up the rear of the car.
Next Sunday I'll find out if it makes much difference.
Yes.
Take a look back at some of the pictures that are in this thread and you can see where the original hoops were, and where the new bar now is.
WWSCC
Guessing that that stands for Western Washington Sports Car Club?
Randy Forbes
Old 10-14-2002, 06:27 PM
Butting back in
Mein Auto: GS500F
Oops - yes. They run under SCCA rules, as far as I can tell...
