Old 03-01-2006, 08:43 PM
avalys's Avatar
avalys avalys is offline
Nothing specific
Mein Auto: 03 325Ci 5spd SP
Koni FSD Review (very lengthy)
The roads here in Boston are horrendous. There's just no other way to describe them. They are mysteriously lumpy, pothole-ridden, uneven, jagged, filled with recessed seams, joints and abrupt transitions between surfaces and angles. Nearly all of the manhole covers and storm drains are at least an inch below the pavement surface: the rest are an inch above it.
BMW did a good job with the suspension on my 2003 325Ci: I never had any issues back in Connecticut. But it is hopelessly unsuited for this level of crappiness. Ever since I first came up here two years ago, every trip I've taken in and around Boston has made me wince and cringe. It's not so much the rough ride itself as the constant worry that I'm going to damage the car: driving a friend's old beater recently, it didn't bother me at all.
The highways are not so bad - it's the local roads that really suck. And it's not just the city itself - pretty much nowhere within the route 128 loop (approximately a half-circle with a twelve-mile radius) is any better. It's irritating enough that I often find myself getting on the highway and driving twenty miles to buy something that I could get within three, just to get to better pavement.
Until recently, I've just put up with this. After all, there didn't seem to be that much I could do about it: the car isn't lowered, and I have the stock seventeen-inch rims. And I certainly didn't want to compromise the handling and precision that I bought a BMW for by installing softer shocks.
Then, at the end of last summer, I read an article in Roundel about a new shock absorber that Koni has developed, that they called "Frequency-Selective Damping", or FSD. The idea is that they can respond differently to high-frequency inputs vs. low-frequency ones: there is a valve inside that sits in parallel with the rest of the oil passages, but only opens when the shock is hit fast enough with sufficient force. This means that, for high-frequency inputs (those produced by the wheel when it hits a pothole or other significant bump), it can respond softly and soak up the impact, but for low-frequency ones (produced by the movement of the car body as you brake, corner, change lanes, etc.), it can respond stiffly. So, the idea is that, theoretically at least, these shocks can improve handling and ride quality simultaneously.
This has always been at least partially possible with adjustable shocks, or systems like the Praxxis air suspension stuff. But adjustables are inconvenient - you have to decide how you want the ride before you start driving, and actually changing the settings is sometimes cumbersome. And the Praxxis system is very expensive, not to mention heavy and complicated - it requires installation of an air compressor, central control unit, and so forth. The FSDs, on the other hand, are just ordinary-looking shocks that install like any other set, and require no adjustment. They're simultaneously stiff and soft, depending on the circumstances.
Always a fan of cool engineering, I was intrigued. These sounded awesome. I did some research, and decided I'd buy a set and install them in the spring, once I had switched back to my summer tires. But sometime in January, I decided "Why wait?" and bought a set from Tirerack.
It was a bit of a risk, because I could only find one review (the one from Roundel). But I've had them on the car now for about 1000 miles, and all I can say is: they're amazing.
I was initially worried that, despite the promises, they would make the car ride like an old Buick: soft, mushy and floaty. That is definitely not the case. When I drove away from the shop that did the install, my immediate impression was that they were significantly stiffer than the stock shocks. The car feels tighter, lower to the ground (even though it isn't), and just more stable and controlled in general. The difference is especially noticeable when cornering and changing lanes - the FSDs allow a lot less initial body roll than the stock sport shocks.
But the improvements in handling are absolutely nothing compared to how these things handle bumps. For most irregularities where the pavement is unbroken (dips, rises, gentle lumps, etc.) the car still feels stiff. But anything more abrupt (usually anything that breaks the pavement - potholes, expansion joints, sudden surface elevation changes) just gets soaked up. I'd say it takes anywhere from 50% to 80% of the edge off.
It's really almost surreal, because at no point does the suspension feel soft. Yet somehow, the same bumps that used to feel and sound like driving over exploding grenades just turn into muffled thumps.
The difference is especially noticeable when driving over a patch of rough pavement that has multiple bumps and abrupt ridges in succession. There's a stretch of southbound Route 1 just north of Boston that's like that, and it's a fairly sharp curve as well (just before the Mystic River bridge, for anyone in the Boston area). Going over it before used to be miserable: I'd feel the wheels hopping around, and the rear of the car sort of squirming as they lost contact with the road and then regained it. The night after I had the FSDs installed, I drove over it, and I actually first thought that the DOT had repaired the pavement. Even in a corner, the FSDs remain stiff with respect to the motion of the car, while simultaneously handling the bumps.
These things are so good, I think I actually got a flat tire by being a little too carefree about what I drove over.
Tirerack did a test of the FSDs vs. the Koni Reds and Yellows, and the FSDs actually turned in faster lap times overall, probably because they maintain better contact with the road in corners. Best of all, they're not that expensive, at only $680 or so. Also, the shop that did the install said that the kit was excellent: well put together, fit perfectly, etc.
All in all, driving my car on these roads no longer feels like abusing it. I can't recommend these highly enough to anyone who has to travel on unpleasant pavement.
Old 03-01-2006, 09:06 PM
EdCT's Avatar
EdCT EdCT is offline
zeddy
Mein Auto: '06 330cic ZHP / '07 M35x
Thanks so much for the review, I've been wanting to try these on the Z4 and yours is the first write-up I've seen outside the Roundel article.
The Z4 is very stiffly suspended, the ride's rough (especially with the run flats), but the biggest problem is how it hops and tramlines over rough surfaces.
Definitely going to put them on, thanks again.
Ed
Old 03-02-2006, 06:49 PM
Purpleboy Purpleboy is offline
Mein Auto: 320IA
I've had them on for a week now together with Eibach Prokit springs. My conclusions are:
1) car corners much flatter, braking dives and acceleration lifts are reduced significantly
2) more comfortable than stock setup despite the lowering springs, you hardly feel the small, high frequency bumps
3) car seems to "stick" to the ground
4) more traction over the same corners even at much higher speeds
5) car looks really good with a lower stance
I got them cos I ordered some 19" rims and was hoping these would balance out the harshness. I'm still on 17"s now but by the feel of things, it looks like the theory is actually going to work.
As I don't track and drive in a legal fashion 98% of the time, I couldn't be any happier with the FSD's. Nothing at this price point gives you 2 seemingly opposing traits of suspension behaviour.
Old 03-02-2006, 10:01 PM
330ximd's Avatar
330ximd 330ximd is offline
Advocate de diabolo
Mein Auto: 330xi '04, X5 35d '11
Hi Avalys,
I am also in Boston, do you recommend them for an XI model w/out the sports suspension? These roads are making me insane, and I am also considering doing something like this maybe next year. I am hoping though that I don't see much change in suspension unless I am driving on awful roads, because I am used to the XI nonsports suspension. Anybody's thoughts are welcome, of course, thanks.
Old 03-03-2006, 12:52 AM
avalys's Avatar
Nothing specific
Originally Posted by 330ximd
Hi Avalys,
I have never been in a non-sport E46, so I don't know they ride. But in short, the FSDs feel stiffer than the stock sport suspension all the time, except for the fact that they also perform very well on bad roads.
If you like the non-sport suspension, I'm not sure if you'll like the Konis. They definitely don't give you a soft ride: you get a stiff ride, just somehow, the bumps don't bother you as much.
Old 03-03-2006, 05:00 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
Thanks for the excellent review.
Old 03-03-2006, 07:36 PM
Ace Ace is offline
Mein Auto: '01 325Ci
Thanks for the review!! The roads here in Toronto sound similar, and I have been wondering what I can do. I might have to check these out...
Just a question for you though, did you just change the shocks? Or did you also change the springs from the OEM Sport package?
Old 03-03-2006, 08:16 PM
avalys's Avatar
Nothing specific
No, I used the stock springs.
Koni actually says that the FSDs are only to be used with the stock springs / ride height. There are two different versions, one for the E46 with the sport package springs, and one for the E46 with the standard ones.
Old 03-04-2006, 10:37 AM
330ximd's Avatar
Advocate de diabolo
Thanks for the feedback Avalys, excellent review as well, I'll look into it more, thanks again!
Old 03-05-2006, 04:15 PM
tom busby tom busby is offline
Mein Auto: 95 318i*01 325i*97 528i
Thank you for the great post.
Old 03-08-2006, 12:49 PM
cncmastr cncmastr is offline
Send a message via AIM to cncmastr
Mein Auto: E46, E30, E53 and E39
Great review. Thanks for helping my want to spend my money...
E46 - ZCP | E30 - 318is | E53 - 4.8is
DIY Video Channel - http://www.youtube.com/user/BluePurpleRedGuides
Old 03-08-2006, 02:27 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Thank you for the contribution to Bimmerfest!
Old 06-20-2006, 01:27 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Avalys,
Just checking in to make sure you still have the same feelings about the FSDs. I'm thinking of picking some up for my ZHP.
Thanks,
Kris
Old 04-18-2009, 06:01 AM
Gryphon's Avatar
Gryphon Gryphon is offline
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
Let me know what you find out, and I'll do the same.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 04-20-2009, 07:08 AM
ewc ewc is offline
Mein Auto: 330cic 6mt
I've been pretty happy with my FSD/Eibach setup. It mostly rides better than stock, absorbing expansion strips and potholes better than stock. On rough undulating roads (e.g. concrete overpasses and bridges), it is firmer that stock, so you feel more vibration transmitted to the chassis -- kind of like driving on cobblestones.
Handling is slightly better than stock, but not dramatically so. Non-progressive springs and sways would do more for handling. I have not experienced any floatiness at high speed.
Also note that installing the FSDs alone will give you a slight drop for some reason. My car is pretty slammed on the pro-kits, which surprised me. That's the only real downside for me, as I did not want such a low drop. I have to be super careful on driveway ramps and parking garages, otherwise I will scrape (or bang the undercarriage!).
Also, regarding potholes, I feel the FSD will actually help prevent rim bends, as they are able to absorb large impacts much better than stock. I could be wrong, though.
Old 06-22-2006, 10:30 AM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG
Are you sure the old shocks were not worn out ? How many miles were on the old shocks ?
04 BMW M3 Coupe SMG-II Carbon Black
Old 06-22-2006, 10:35 AM
NH-SHICKS NH-SHICKS is offline
Mein Auto: 325i, 4Runner
Believe me the roads are terrible in Boston. The worst roads in AZ are better than the best in Boston.
Steve
Old 06-22-2006, 11:22 AM
Steve
I know, we have great roads for me most part in Arizona. Only a couple areas where there is a lot construction have been driven to shreds but the other roads are awesome.
Old 06-22-2006, 10:42 AM
avalys's Avatar
Nothing specific
Around 50,000, perhaps.
I asked the shop that installed them (Turner Motorsport) that exact question, and they said they were not worn out at all.
Old 06-22-2006, 11:23 AM
Very impressive then. Koni has always been a great manufacturer. I used to live 15 minutes away from their factory :-)
Old 02-15-2007, 01:35 PM
nick anderson nick anderson is offline
Mein Auto: bavaria, 530iT, 528iT
Koni FSD shocks on 1999 BMW 528iT
Thanks to this thread, I purchased recently a set of Koni FSD shocks that became available for the E39 5 Series wagon last year. What an improvement in ride quality! I have a 1999 528iT with the standard suspension, and Michelin MXV 4 Plus 16" tires. The standard factory suspension is substantially stiffer than that on the E39 sedan or my 1994 530iT, although not quite as bone jarring as the E39 wagon with sport suspension and low profile and/or run flat tires.
Although the handling of my E39 wagon was superb from the get go, the ride was disapointedly poor to mediocre under most road and load conditions, especially for a BMW and in comparison to my 1994 530iT wagon. This has been a common complaint from many E39 wagon owners. The only partial solution I had found previously to the poor ride was to put three 50lb bags of sand in the luggage area or load up the car with 4-5 people and luggage. I have driven several other E39 wagons so I know that this ride problem was not unique to my vehicle.
I would roughly estimate that the ride has improved (on a 10 point scale) from a 4 to a 7 (my 530iT I would rate at an 8), at the same time the handling has improved from a 7 to an 8 (my 530iT would rate a 5 or 6).
Anybody who is not happy with the strange new ride/handling balance of several other recent BMW models (Z4, X3 and X5, Mini etc) should give these Koni FSD shocks a shot. For me, it has transformed the E39 wagon driving experience and made it the finest driving experience of all the BMWs (seven) I have owned over 35 years!
Old 12-08-2007, 09:07 PM
Haasman Haasman is offline
Mein Auto: 07 335i
Koni FSD?! Questions ....a smoother ride?
I'm driving an 07 335i with sports suspension and it is great, I love it ... but I have noticed a bit of bobbing over rough surfaces. I would rather keep everything as stock as possible but wonder if there is something to improve the ride smoothness.
My girl has sometimes complained of feeling a bit nauseous, not from the firm ride but from the small kind of bobbing motions. I've noticed it also.
I am wondering if these other shocks would smooth the ride.
Your suggestions are appreciated,
Haasman
Old 12-12-2007, 12:19 AM
dynosor's Avatar
dynosor dynosor is offline
Mein Auto: 2003 E46 330i
Haasman
FSD shocks may help, but before you spend the cash try something simple:
Increase your tire pressure by 3 psi over whatever it is set to now, or at least 33/ 36 psi F/R. A stiff suspension can cause a bobbing effect on the tire sidewall if the tires are too soft. As winter has come, the shocks become stiffer and the tires softer, exaggerating this effect.
The effect is due primarily to shock friction, and will subside after the suspension is fully broken in.
Old 01-06-2008, 10:47 AM
Dunlin Dunlin is offline
Mein Auto: 2001 BMW 330i
Koni FSD
I had a set of these put on my 2001 330i about a year ago, and my car drove a little better than it did with stock shocks, but I had to replace all 4 wheels because they were all badly bent and now I am in the process of replacing the Koni FSD shocks with a new set of stock shocks. So if you live someplace with less than perfect roads like I do here in NYC, I would recomend sticking with stock BMW shocks.
Old 01-29-2008, 06:49 PM
Watchdog Watchdog is offline
Mein Auto: E90 335i; RX 350 (wife's)
Hmmm the OP said that these shocks were great because of the poor roads in Boston and you're saying they're not good on your car because of the poor roads in NYC?
You seem to have a different opinion than the OP. Could you explain why the shocks were responsible for your bent wheels and why stock shocks wouldn't have bent your wheels?
Similar Threads
Koni FSD Shock Test Rudy@Tirerack Tire Rack's Tires, Wheels, Brakes & Suspension 0 12-19-2005 08:20 AM
Opinions on Koni FSD shocks? avalys E46 (1999 - 2006) 5 11-30-2005 10:51 AM
H/K Traffic Pro Review - The Real Review Jim E. E36/7 Z3 (1996-2002) 331 08-17-2004 07:14 AM
Koni Reds or Koni Yellows Andy Tire Rack's Tires, Wheels, Brakes & Suspension 5 11-26-2003 04:56 PM
