Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 06-08-2006, 07:16 PM
Jon Shafer's Avatar
Admin • Owner • Enthusiast
Bimmerfest Founder
Mein Auto: E92 M3 Cp
Thumbs up E30 Resource Thread
The most important and relevant questions and helpful information pertaining to the maintenance, restoration, or modification of the beloved E30 BMW 3 Series gets posted here.
Please chime in.
Edit:
This thread consists of:
The official Bimmerfest E30 FAQ thread
E30 DIY Links
Sources of Vacuum Leaks
E30 Owners Manual
http://jon.bimmerfest.com/bulletins/e30_manual.pdf
(to download, right click then "Save As")
Please note: Requires Adobe Acrobat Reader to view.
Please also allow ample time for this 8MB file to download...
Last edited by markseven; 02-05-2012 at 07:56 AM. Reason: Added Owner's Manual link
Old 06-08-2006, 10:05 PM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Please chime in.
Thanks Jon I've noticed we have added a few new members and we seem to be answering ALOT of the same questions over and over again so I asked Jon to give us a sticky for our MOST commonly asked questions (Timing belt DIY,SI batteries). This is long overdue and hopefully will help tone down the amount of threads being posted that are cluttering our board. In the next few days I will be digging up some of the DIY's I have written and posting links here. If you know of a DIY or tip feel free to post them here.
For ABS Light info: http://www.bimmerfest.com/forums/sho...d.php?t=148911
Cluster issues unrelated to SI's:http://www.bimmerfest.com/forums/sho...d.php?t=123222 http://www.bimmerfest.com/forums/sho...d.php?t=123934
Old 10-01-2007, 06:42 PM
mattdk318i's Avatar
mattdk318i mattdk318i is offline
another E30 nut
Send a message via AIM to mattdk318i Send a message via MSN to mattdk318i Send a message via Yahoo to mattdk318i
Mein Auto: 91 318i and 90 Cabrio
Someone needs to add something to this thread. Its been a Year!!
No where else id rather be
Old 11-12-2007, 04:49 PM
stategorgeous stategorgeous is offline
Mein Auto: BMW 325i
What common procedures/parts need addressing?
Old 11-12-2007, 04:53 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
For you, Timing belt would be a major priority.
Fuel filter
rear shock mounts
Old 12-04-2007, 09:12 AM
The Barvarian The Barvarian is offline
Mein Auto: 2003 325iT
Looking for e30 HP #'s by model and year.....
Old 01-20-2008, 09:25 PM
my 87 325m-tech my 87 325m-tech is offline
Mein Auto: 89 325is
you should add wheel and tire info!
Old 01-22-2008, 09:59 AM
HarryN HarryN is offline
Mein Auto: 1989 325IX
Perhaps some info on sensors and symptoms:
- crank angle sensor
- mass flow intake sensor
Old 03-04-2008, 08:29 PM
turdlecharge's Avatar
turdlecharge turdlecharge is offline
Mein Auto: 89 325is
i think it might be helpful to throw in a sticky for possible vac leaks... maybe it will alleviate some questions
2 good ones i found were
1. o rings on the oil dipstick
2. clutch master cylinder hose off brake master cylinder leaking
has anyone figured out how to make the elbow that goes into the intake from IACV not leak? im thinkn rtv or possibly tappn it and threading it for a brass elbow!
Old 03-04-2008, 08:32 PM
downhiller's Avatar
livin large
another good one is the valve cover gasket. had that on my midget, took me about a week to figure that one out.
Old 03-04-2008, 10:49 PM
SWISS's Avatar
On Top
JB weld those elbows back into the intake.
Other notorious ones are the oil drain back tube seal, hose fittings on the throttle body, injectors not seated, valve cover.
Old 03-05-2008, 04:40 AM
oldtimer oldtimer is offline
Mein Auto: 2005 Z4, 07 Road King Cla
What indication did you guys experience that prompted you to check for leak. Better yet: if the valve cover seal is leaking what indication one can experience. Here's my situation. I replace the TPS and clean the ICV. the engine light still comes on off and on and a steady light. The idles when I come to stop light or sign then it will flactuate. I can tell the ICV is working and is clean because when you first start the car the rpm will be high for a second or two then it drops to proper rpm. Also, when the car is idling and flactuates then pull the tube from the valve cover. the front tube idle will be smooth but high. Can someone tell me what that indicates aside from idling high.
Old 03-05-2008, 05:21 PM
downhiller's Avatar
livin large
i found mine by mistake, sort of. i had a leaking valve cover gasket, and when i pulled the cover there was a small gap to where the crankcase pressure was released. and after i replaced that, it ran decent until the head gasket went. after i replaced that i have the same syptoms. but as SWISS stated "the oil drain back tube" might be leaking on mine. i kinda found the o-ring on the ground after i put everything back on. and i didnt want to takle that one for a bit.
Old 03-05-2008, 08:20 PM
SWISS's Avatar
On Top
Another spot is the oil cap. Pretty much you need to rev your engine and listen for the hiss. My indication that I had a leak came in the form of poor idle and the infamous 1222 CEL code. Idle I discovered was part vacuum leak but more Bosch plat +4 plugs, M20's don't like them. the other was a O ring I forgot on the oil drain back tube when I did the head. And boy is that fun to do without removing the intake....
Old 03-05-2008, 08:46 PM
Thrax Thrax is offline
Mein Auto: 1991 325i E30
+ 2 on Swiss and Downhiller but come on Swiss. JB weld... I thought you were better than that... Replace, reduce, recycle. Sell your old parts on E-bay and buy new to make up the difference.
Old 03-06-2008, 03:57 AM
The last time the valve cover was off the engine was when I painted it but that was a year ago. It was idling normal my idle problem did not start until just recently. I plan on taking the intake off in the near future to combat those vacuum line. I am going to replace them with steal line with as little rubber tube coupling them together to eliminate the worry of any vacuum leak coming from there and of course the hassel of removing the intake just to get the line.
I will investigate the oil filler cap idea.
Old 03-29-2008, 07:11 PM
blubimmer blubimmer is offline
Mein Auto: 1985 318i BMW
another one
well here is one i found today...got me a can of carb cleaner and sprayed around like everyone else has done before...i was getting the same symtoms idle fluctuates when in neutral...like i said started spraying around the engine looking for that vacuum leak and just could not find anything at all the vacuum lines that i could see....then just for the sake of it...i sprayed at the bottom of the fuel injectors and lo and behold i had a reaction...found out that the o rings on my fuel injectors were deterioted and was leaking there...changed the o rings and finally got to adjust and time the engine so that it did on rev up and down...hope this help some one out too...
Old 03-30-2008, 12:28 PM
Mike_Check Mike_Check is offline
Account close at users request
Mein Auto: .
I thought this was a sticky...not a q/a forum...
Old 03-30-2008, 12:42 PM
Banned
Mein Auto:
Shouldnt you be chasing genetic throwbacks? Or something?
Old 03-30-2008, 08:48 PM
Mein Auto: .
Old 08-10-2008, 06:27 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: 1987 325i, 378K
Good thread. I hate to admit that a few years ago when I was sorta green on vacuum leaks, I was looking all over for one with no luck. Later a fellow came by to buy something I had on Craigslist, he was there before me and he heard my engine on the way up. Turns out he and his dad are E-30 o'philes, we got to talking and he said "why-oncha pop that hood and start it up again." I got out the carb cleaner and it was the biggest possible source of vacuum leak -- the intake manifold gasket!
Oopsie.
Idles just fine now.
cmac
As I know more of mankind I expect less of them, and am ready now to call a man a good man upon easier terms than I was formerly. - Samuel Johnson
Old 02-23-2010, 06:21 PM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
California Smog Check Assistance Program
If you meet certain requirements you can get up to $500 from the State of California to repair your emission control equipment:
http://www.autorepair.ca.gov/80_BARR...sist_FAQs.html
http://www.autorepair.ca.gov/80_BARR...ms/CAP_App.pdf
WTB:
E30 | E28 | E24 | E23
| Minty Seat Belt Receptacles - Front
Old 01-22-2009, 08:02 AM
Lars_5687 Lars_5687 is offline
Send a message via Yahoo to Lars_5687
Mein Auto: E30
Cool Vacuum leaks :-/
So my cars got some miles on her around about 500k but hey shes still stock and ran great til i hopped in and she didnt want to idle and after i revved her up to 3 grand she cleared up now its a constant miss Anyways heres a few things going on.......in 5th gear at 2500 rpms i can let out of it and see the economy gage go near 40mpg and it sounds like shes cuttin out I dunno the only thing i can figure is a vacuum leak to happen in one night
Old 01-22-2009, 08:31 AM
Banned
Mein Auto:
Could be a few things. Id start by checking the O2 sensor and AFM.
Old 01-22-2009, 12:39 PM
Mein Auto: E30
Well i played with the distibutor and i got a lil better timing now its not a "sputtery" but now I lose HP at 3 grand and it wont Idol..ive replaced half the vacumm lines i could see im prolly missing the key one
I will never die for I drive with the angels BMW E30
bmw diy, bmw do it yourself, e30 diy, e30 do it yourself, m50 e30
Similar Threads
The official "alee sucks thread" sucks thread nate Off-Topic 22 06-03-2004 03:37 PM
Official Count @ Bimmerfest? manik///m3 General BMW 3 04-22-2002 02:23 PM
official party hotel for bimmerfest ???? jAb General BMW 5 04-18-2002 04:26 PM
It's official, Bimmerfest is no longer utopia Spiderm0n Off-Topic 32 04-17-2002 06:06 PM
