Old 12-06-2002, 11:36 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Z3 HVAC bulb replacement
The following pics show where I'm at.
Will order the back plate for clearer pics. Have the front piece to show how it comes apart.
The bulbs are part of the bulb socket. More to come.
Old 12-08-2002, 02:28 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
I just replaced both those in the black car last month.
Able to access them through the radio opening (less trouble than removing the console, but still a pain).
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 01-13-2009, 07:53 AM
12/8/02. Those bulbs lasted a lot longer than the originals...
Now, six (6) years later, since this thread is still used for reference, I'll update it with some new pictures.
Note that while not shown, the head unit has to be removed first, so be sure to have the security code if it's the factory unit. The CD head unit requires a 2.5mm Allen wrench to remove, the cassette player takes a special five (5) sided tool available from the dealer.
Randy Forbes
Old 01-13-2009, 09:40 AM
Ron Stygar's Avatar
19,585 Miles
My 318ti is similar and uses just one of the same bulbs. Going on twelve years.
Old 01-13-2009, 12:13 PM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
Great pictures Randy and btotoro! Thanks.
Old 03-22-2015, 06:42 AM
Since I can't edit my own post to correct the broken links, I'll quote it...
Randy Forbes
Old 12-15-2002, 07:11 PM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
Bulb Replacement Help
The left side of my heat/ac control panel light is out. I pulled the radio and using a mirror found one bulb E 106 (its sort of in the middle) I think I see E105 way down under the flap control but how do I get e105 out? I guess they twist out but I can barely touch the bottom one. No one said working inside consoles was easy but this has me stopped. HELP
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 12-15-2002, 09:28 PM
Ron Stygar's Avatar
19,585 Miles
Re: Bulb Replacement Help
On the lower left and right side of the radio opening there are screws that hold the HVAC unit in place. Once you have the screws out, there are two tabs at the top of the HVAC assembly. Pull up on these and it releases the HVAC unit. This might help.
Old 12-15-2002, 09:32 PM
What is it with that left bulb?
Same one went out in my 99!
You're halfway there...
Pull the knobs off the HVAC control and then push on all three (3) stems evenly to "pop" the control loose from the console.
Keep one hand behind the control to catch it when the clips disengage from the console.
Now you can get the whole control up to the radio opening to remove that stubborn bulb/holder.
When I put mine back together, the hardest part (but not insurmountable) was getting all the HVAC control mounting tabs lined up; TIP- start with the tabs at the bottom first and insert them all evenly. Make sure the bulbs (you are changing them both, right?) illuminate before putting the knobs back on.
Let me know if I can be of more help...
Randy Forbes
Old 12-16-2002, 11:25 AM
A Clean Windshield
Bulbs
Thanks, I guess I should stop training this mouse to use its paws. I haven't made much progress. It just keeps finding cheeze doodle crumbs under the seat from my trip to homecomming.
Old 01-06-2003, 05:22 PM
Ron Stygar's Avatar
19,585 Miles
Received the backplate today. Comes with lamps and the blower switch.
Lamps are sure tight in place. Had to use long nose to get them out. Not sure how you would do this with it in the dash.
Old 10-16-2011, 03:39 PM
Liders Liders is offline
Mein Auto: BMW M Roadster 2000
Preparing to remove the panel on a 2000 M Roadster through the radio opening, may loosen/romove the passenger side kick panel. I can see that the fan selector switch is a pull-out electricl connection, see the three cable connected to the lever arms behind the temperature control guage, and see the disconnect on the air selector knob (electrical disconnect, right?). Question is, I cannot see how the cables are connected to the lever arms. By looking at other threads, it appears that the arms each have a round slot the some type of tab at the end of the cable fits int. Appears that I need to move the cable ehough to align the tab on the cable with the opeing on the lever arms, slide the tab through and out. ANyone got a picture of the cable end or advice on how to disconnect and reconnect the cables in a tight space? Thanks!
Old 10-05-2012, 01:28 PM
DogFather DogFather is offline
Mein Auto: Expedition
Sorry to resurrect a dead thread, but I have something to add.
Two years ago, I performed a fix similar to the one described and pictured by 98FLSTC. My posts are still up there.
My solution was much more crude, and involved a nail with a fat, rounded head rather than the special "knob" type part he found. Mine worked great for two years, but last weekend it finally crapped out for good. I guess my drilling caused a crack? I dunno, I haven't opened it up yet.
Anyway, I went looking for BMW part #64118398937. The median price I found was $219. The lowest was $192 (but I'm not sure they really had it in stock) and the highest--you guessed it, from a REAL BMW DEALER was $515.
Then I checked ebaY!!!!
$86.27 shipped. They have three other assemblies listed at $150 OBO. It is certainly worth considering.
If someone were really smart, they'd figure out how to make a mold for just those little plastic arm thingys. For less than the price of one assembly you could probably manufacture 100 of them, and sell them for $50 each.
Old 11-19-2013, 06:56 PM
respinosa respinosa is offline
Mein Auto: 2001 Z3 Roadster
Z3 Heater Control Panel
Hi Ron, I have 2001 Z3 Roadster 2.5, and the temperature control knob broke. Where can I get the part(s) to repair? Thanks!
Old 11-20-2013, 05:23 AM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
You say the knob broke, but likely you mean the control arm or some other part behind the knob itself.
Put your car's last 7 VI into RealOEM.com and look at the parts for temperature control. RealOEM says the 2.5 ended in 09/2000 so I assume you have a 2.5i.
http://realoem.com/bmw/showparts.do?...56&hg=64&fg=20
It appears that you may have to buy the whole Base Plate (item 3 with PN 64118398937), which is why this DIY thread is about fixing just the control arm in the base plate.
If you do need that whole base plate part or any other part, go to BMW South Atlanta's site and enter the part number to look at photo and price:
http://parts.bmwofsouthatlanta.com/p...118398937.html
It is always good to know the actual part number and retail price of what you want.
Then you can see if another vendor has it cheaper, or search eBay for "bmw z3 climate control" and see less expensive new and used parts.
http://www.ebay.com/sch/6000/i.html?...ssories&_rdc=2
Old 12-10-2013, 04:54 PM
Thanks Vinatag42, that's exactly what I needed to know!
Old 01-06-2003, 05:31 PM
A Clean Windshield
Changing the H/ACBulbs
I'm quick at this one now. Thanks Ron and Randy.
Loosen two radio screws, pull out radio, pop off radio connector, off with antenna, out comes radio, flip two clips on heat/ac panel (I don't have any screws), flip panel, grab bulbs with needle nose (they are tight) in goes new bulbs, done!
Old 01-06-2003, 06:42 PM
My 99 didn't have screws either.
Not sure about the 01, but I'll let you know in a couple of years...
Randy Forbes
Old 01-06-2003, 10:23 PM
Adam12Hicks's Avatar
Adam12Hicks Adam12Hicks is offline
Send a message via AIM to Adam12Hicks Send a message via Yahoo to Adam12Hicks
Mein Auto: 06 Sapph Blk M Roadster
Ron, now you can fix our heater control!
Just invent a different shaped arm coming off the heater control that would somehow, miraculously result in an even transition from cold to hot!
2006 Z4 M Roadster
2005 X5 Kid Truckster
1991 318is e30 Play Car
Old 01-06-2003, 10:32 PM
Ron Stygar's Avatar
19,585 Miles
Re: Ron, now you can fix our heater control!
Not going to happen. Connect to:
http://bimmerfest.com/forums/showthr...threadid=17020
Old 10-11-2005, 12:46 PM
corgicoupe corgicoupe is offline
Mein Auto: 2006 M Coupe
From the pictures in this thread and the diagrams in the Ron Stygar quote, I cannot figure out how my temperature control knob is acting like an on/off switch. With the AC running, just a slight twist of the temp knob makes hot air come out.
Old 10-11-2005, 12:59 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
moving the temp. control opens the blend door to allow heat from the heater core into the ducting, hot air will always over take cold air
Old 10-11-2005, 01:06 PM
But it used to be gradual. Turn a little and get warm air; turn a lot and get hotter air. Now, just cracking it causes the air to be full hot; no gradation possible.
Old 02-04-2008, 11:06 AM
QuestMCoupe QuestMCoupe is offline
Send a message via Yahoo to QuestMCoupe
Mein Auto: 2000 M Coupe
I know this is an old thread but I'd like to thank Ron for posting those pics. They definitely helped locating the bulbs on the HVAC.
Does anyone know a place online that sells these bulbs so I dont have to drive down to the dealer and order them?
Old 02-04-2008, 11:54 AM
greyish's Avatar
greyish greyish is offline
tire consumer
Mein Auto: 99 z3c
here.
There are others, but that is a good price relative to others.
Of course, that site (if I'm not mistaken) also came to my knowledge via Ron.
