Old 12-08-2002, 02:04 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Rotor Paint
Eastwood. Stainless steel finish. I might redo in a more silver color. Still have a second coat and cleaning work left to do.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 12-08-2002, 02:05 PM
JonM's Avatar
Moderator
No message.
Jon Maddux
Old 12-08-2002, 02:22 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Oops!
Is that when the phone rang?
(spot on floor)
Even more labor intensive, I used Techline's thermal dispersant coating on the Healey's rotor hat and edges (plus rear drums).
Surface must be blasted and cleaned with solvent; mask off all areas that are to remain uncoated; use airbrush to apply a ridiculusly thin amount (like .0015"); cure in an oven at 300 degrees (part temp) for an hour.
And you call yourself an enthusiast!
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 12-08-2002, 02:24 PM
JonM's Avatar
Moderator
Yeah, I'm taking the easy way out on this one.
Jon Maddux
Old 12-08-2002, 02:36 PM
JonM's Avatar
Moderator
Spots on floor are "brake dust with brake cleaner" soup. will clean right up.
Always good to talk to you.
Jon Maddux
Old 12-09-2002, 02:11 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
Looks great! I just ordered some Eastwood brake drum black for the Z3's rotors. In the spring I will get the Euro floating rotors from the M3.
Old 12-10-2002, 01:22 AM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Jon, why did you paint the aluminum hats? They clean up nice with scotchbrite pads.
I used the Griots cast iron color. Had the rotors bead blasted. Still a pain in the ass to paint. Three coats using Q tips etc.
It doesn't last. The rust starts coming though. Becomes an annual thing.
You also have to paint the ID on the disc surface. 1/4 inch on the back and 1/8 inch in the front in my case. OD, 1/8 inch.
Looking into powder coating the rears and cad plating the fronts.
A masking nightmare, just like doing the wheels.
Old 12-10-2002, 08:40 AM
JonM's Avatar
Moderator
It was a tossup on the hats. I wanted them to look uniform front and rear.
I don't think Griot's carries their paint any more. The Eastwood stuff is really nice. Don't get it anywhere you don't want it to go. I cannot get it off. Fingernails included. Can says "contents partially unknown". Andy bought the matte silver which is a shade lighter than what I bought. Of course he has solide rotors in rear which makes his work a little easier.
I did do the IDs, just like you. I cleaned any overpainting with scotchbrite.
I will not be pleased if this paint does not hold up. This project was a crapload of work. I did not bead blast. I used wire wheel on my Milwaukee
and also a wire pipe cleaner. I watched Office Space 6 times while I prepped them.
If powdercoat holds up better and/or cad plate, I am interested.
Jon Maddux
Old 12-10-2002, 08:44 AM
JonM's Avatar
Moderator
If I go with RK2s, I will paint the spacers too.
Jon Maddux
