5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
01+ Broken Headlight Adjuster Fix (E39)
Just want to share my fix for 01 - 03 E39 Headlight adjusters. I found the parts at http://www.odometergears.com and thought I would give it a shot. Parts worked out great, it's nice to have headlights that don't point down.
PDF DIY - Part 1 - http://www.bimmerfest.com/forums/att...9&d=1165817474 Part 2 - http://www.bimmerfest.com/forums/att...1&d=1165817580
2002 540iA Sterling Gray 1999 540iT (retired) |
hey another E39 owner in DFW, welcome. and those adjusters will probably break again in due time. its just how it works i guess. id try to layer them with something that would support them. maybe JB weld?
Lots of companies make tiny parts out of billet alum. for R/C cars, would be nice to see somebody start building parts for full size cars that are prone to failure. Quote:
email me the PDF:
chivas228 at gmail.com
americandan.com
![]() ![]() ![]() It takes a lot of work to be lazy. |
Chivas:
DIY .pdf on its way to you.
thanks!! i got it... trying to cut it up in 2 so it can be attached as 2 files.
americandan.com
Great find. My adjusters aren't broken yet. I look forward to reading more about your fix.
Sent from my iPad...............no one cares ![]() ------------------------------------------------------------------- '03 530i 5-speed, Sport & Premium Pkgs |
Now why didn't I think of that? 2 files? If you have any trouble let me know, I can go back in and edit. I did this in PowerPoint.
Chivas:
I made some changes. Hope this helps others. If anyone needs higher resolution pics, just PM me. Mike
Very nice write up! Thank you a bunch! I will reference these when I get my new adjusters. I HATE driving at night right now.
2007 335i Coupe MT - Space Gray Metallic / Coral Red / Gray Poplar Options - Premium Package, Sport Package Mods - V1 Fusebox Hardwire, OEM Alarm System, Llumar 20% Tint, 3M Paint Protection Film Work I've done - OEM Alarm Install, V1 Hardwire 2001 540i Sport MT (Traded) - Alpine White / Black Options - Premium Sound (DSP), Rear Sunshades Mods - Koni FSD/Eibach, Axxis Deluxe/Brembo, RP Synchromax, V1 Hardwire, DICE HD, Aluminum Adjusters, CDV (ZR), Tint |
Do you have oem ae on your headlight?
Yes, original OEM headlights .........
putting this in the FAQ. thanks!!!
americandan.com
Great DIY write up!!!
Few odd questions: a) where stated in write up, "thread the new pieces on the existing headlight adjustment white screw", is the cutting of the new threads necessary on the new piece done by the screw with the 10mm nut (that can also be turned by the white adjuster screw but not advised), at the direction shown in following picture? ![]() Or, maybe i got this thing all wrong in how the new adjuster piece is screwed/threaded on to the existing screw. b) In the following picture, how are the A and B adjustments affect the proper alignment of the headlight? ![]() c) After cutting the new threads on the new pieces, is it recommended to still use the 10mm nut to do final headlight adjustment? Or use the white adjuster screw? Thanks much! Last edited by gixxer; 12-12-2006 at 12:32 AM. |
Damnit if only I got balls to open up my headlight! Anyone in the bay want to do mine?
Gixxer:
Question = a) where stated in write up, "thread the new pieces on the existing headlight adjustment white screw", is the cutting of the new threads necessary on the new piece done by the screw with the 10mm nut (that can also be turned by the white adjuster screw but not advised), at the direction shown in following picture? Answer = correct. I turned the 10mm black nut clockwise(below the white adjuster knob) to thread the new piece on the threaded rod inside the chassis. The new piece did not look like it was threaded, and it required some torque to run all the way up to the end. Do not use the white knob to do this, the teeth cannot take the stress. Once you have run the piece back and forth a few times, the white knob will handle all future adjustments. Question = b) In the following picture, how are the A and B adjustments affect the proper alignment of the headlight? Answer = (A) seems to be the main adjustment for height. I think (B) is for the high beam as it did not seem effect the low beam pattern. I never had the high beams on when I set the lows, so I am not sure. I could not find any info in the owners manual on headlight adjustment procedures. Maybe someone else will chime in with additional info.
dude its so easy only 4 bolts hold the whole thing in
This may sound stupid but how do you know if this repair is needed. I just received my 01 530 with HID and it seems to be point straigth down, i turned the screw at least 5-8 rotations with no noticable difference on the wall. I am wondering if my is busted also.
John 2001 530i Sport Titanium Silver Premium Package MKIII Navi/CD changer |
This may be a little off the subject but I have 1 in 3 people flash their high beams at me even though just my low beams are on. I have the auto leveling HIDs and am wondering if thats normal or could they be adjusted too high? Any input would be greatly appreciated, especially by wife.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot. |
i have another sorta off topic Q...
if you have say a 99 like i do, do you have to follow the same steps to change the adjuster? or is their another way for the older model non-angel eye style headlights? thanks |
Crazy Glue Works Great Also!
Good write up. One thing to note is that not all OE AE Headlights will come apart in the oven or with a heat gun, some are sealed with epoxy and will not pry apart.
For example my drivers side comes apart real easy in the oven, but the pass side has will not come apart.
Oscar Dallas, TX 01 540i Sport 06 330i Sport 01 530i Sport 01 540i Sport 6spd
I have replaced my adjusters (both lens)...ordered mine from Odometergears.com ask for Jeff (great guy, easy to deal and very fast shipping) the very next day i got my new adjusters and installed them with ease ( well i baked them and used a blow dryer to keep it warm)...i have another set oe AE i will work on soon
That's a little weird, if you have two headlights on the same car, one glued and one epoxied. |
#25
Epoxy on the lense
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions | EPBB | E46 (1999 - 2006) | 119 | 05-09-2010 04:09 PM |
| Disappearing dash pixels - DIY fix? | TXE38 | 7 Series / 8 Series | 15 | 01-18-2010 04:39 PM |
| DIY "Brake Light Failure" CCM Fix!!!! YEA! | bmwfreq | Do-It-Yourself H.Q. | 14 | 08-16-2006 11:00 AM |
| Is there a DIY for fixing a broken sunroof shade? | wag-zhp | E46 (1999 - 2006) | 11 | 07-21-2005 05:23 PM |
| front brakes-- DIY fiasco-- broken bolt /cut wires | bmw325 | Do-It-Yourself H.Q. | 41 | 04-23-2005 05:13 AM |
